Old 05-30-2004, 04:54 PM   #1
Nvbowtie
Nvbowtie's Avatar
Exclamation Elect short !! Help
Edit: #1 solved = see post below
1. Since I first started - my front park lights don't come on,
or are very faint. They do blink bright when signal is on,
but I have the indicator of both lights out --- (where the turn
both signal lights on the dash stay lit up when the headlight
switch is on).
2. Ok, this just started --> when I turn the key to on position,
my wipers start going, and the wiper switch is in the off position.
I noticed that my electric choke was tapped off the wire to
the wiper motor. When I unplug the wire to the choke my
wipers stop ? HELP SOS
www.unlimited2u.com/chevy
1980 Chevy C-10 Silverado
1988 Chevy Blazer Tahoe
Nvbowtie is offline   Reply With Quote
Old 05-30-2004, 05:31 PM   #2
shavedchevy
shavedchevy's Avatar
I had a similar problem to your #1, my signal indicators stayed on also, I tracked the problem down to the signal wiring on the rear tailights. I guess it's some kinda of safety or something??? I think also that the front signal bulbs my not be seated properly or they could be the wrong bulbs..... it's a start anyways.
Dennis
shavedchevy is offline   Reply With Quote
Old 05-30-2004, 10:04 PM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
Sounds like a ground problem. The circuit is looking for a proper ground and when it finds a pathway it causes that part to run also. I would start wtih the carb wire and isolate it, then I would look at the ground circuit for the turn signals/park lights. The windshield wipers may fix them selves once you have the wires all where they belong.
piecesparts is offline   Reply With Quote
Old 05-31-2004, 09:54 AM   #4
muddyole 69
wiring trouble
this may sound kinda stupid but i had similar trouble and the way I isolated the problem ground was to take a test light and checked each ground until I found where the power was going and corrected the previous owners goof probably not the most effi cient way but I got a truck that does not drain my battery anymore !!
hav'n fun be'n me
muddyole 69 is offline   Reply With Quote
Old 05-31-2004, 10:42 AM   #5
swervin ervin
You get what you pay for
swervin ervin's Avatar
I had a problem with the turn signal indicators staying on and no front park lights in a van I have. After much ado, I figured out it was a front turn signal socket. I checked the sockets many times and never could really see anything wrong with them. I finally got fed up and replaced them anyway. Problem solved.
I think if you wire up the choke right and get it off the wiper motor wiring, this will fix that too.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 05-31-2004, 12:31 PM   #6
Nvbowtie
Nvbowtie's Avatar
Pic of light switch, a while back I found original wire cut
and another hot wire was brought in to power the switch.
-- may help with the think tank?
Old 06-06-2004, 04:00 PM   #7
Nvbowtie
Nvbowtie's Avatar
Ok #1 parking lights is solved.
It was a bad ground connection in both turn sockets,
where the ground plugs into the side of the socket.
It was a good ground to sheet metal, just not in the socket.
I cut of a strand of twisted copper speaker wire and bent it into
a U shape and put it in the socket then plugged the male spade
into it making a good ground connection.
Now on to problem #2
and my courtesy light:
http://67-72chevytrucks.com/vboard/s....php3?t=106928
Old 06-06-2004, 04:08 PM   #8
Nvbowtie
Nvbowtie's Avatar
Where should I hook up the choke ?
or do I even need it 80-120 deg weather ?
