Axle DeCode Please
Can someone please run these numbers please?
Should be from a 72 C-10 THA W236 1 I would like to know the gear ratio. Also. Ive heard it before. But can't remember . . . . You count the teeth on the ring gear an then what? To determine gear ratio that is. Thanks!! Darren
Washington State 1967 Chevy C10 LWB Rodstoration In Progress. 1972 K20 Cheyenne Super |
![]() Join Date: Nov 2002
rearend
It's a 3:07, according to my book.
to determine the ratio you count the teeth on the ring gear and on the pinion gear and then divide the number from the ring gear by the number from the pinion
Ryan |
is there a way to tell without pulling the cover. i was told once you could count how many time the driveshaft rotates to one full rotation of the tire to figure it out. is that correct??
2014 GMC Yukon XL (Wifey's) 2004 Chevy Silverado Crew Cab Z71 |
imdarren
This is what I do to decipher the Rear-end code. Go to: http://www.americanclassic.com/ Click on the VIN decoder on the left side of display. Under axle codes check the year 1971. THA is/was a 3:07
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
