05-30-2004, 10:59 PM | #1 |
slow starter
hey everyone i have a question. my truck starts great when its cold fires on the first spin almost always. when it gets warmed up even a little the starter acts retarded and slow. is this just the solenoid getting hot? could it be something else and how could i fix it? Thanks
Ryan |
05-30-2004, 11:18 PM | #2 |
could be timing or a hot solenoid , check your grounds too . hotter engine = more compression so if the ground was weak it woulndt work as well under harder amps
05-30-2004, 11:43 PM | #3 |
What was I thinking??
It could be a bad or a hot solenoid if it's Heat Soak you could add a remote solenoid or a heat shield.
Ceth
72 K5 that needs lots of parts.. 71 GMC 3/4 4x4 That doesn't need much which is a good thing I don't think I could aford another money pit... |
05-31-2004, 04:38 AM | #4 |
PROJECT 7DEUCE
My also want to check all the connection's and wireing to and from the starter to make sure evrything is clean and tight... I t would not hurt the clean the battery post either if need be.
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
05-31-2004, 08:42 PM | #5 |
I had this same thing last week, went to the parts store and they mentioned a portion of the armatuer (sp?) was bad and when I replaced it I haven't had trouble since. fortunatly mine had a warranty from when I replaced it about 2000-3000 miles back, (thats just over a year ago).
1971 Chevy Cheyenne 383/350 LWB 2wd Built to use, and look good. |
