KEEP ON TRUCKING
clutch pedal help
how do you get the clutch pedel off.switched to auto and want to remove the pedel.thanks
72 cheyenne 2wd lwb 71 k20 sons bassett va |
blood type; Retumbo
it is really quite easy to do. on the R side of pdl assy there is an arm with a clamp bolt. remove those. then swing clutch pedal towards firewall & slide out L side. there is just barely enough room. may need Vaseline
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
KEEP ON TRUCKING
thanks alot
If there is a spring on the clutch pedal, be very careful as you can get hurt.
Jim |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Here's a little picture I snapped awhile back to clarify things a little.....
KEEP ON TRUCKING
thanks for the pic
Tx Firefighter,
Very nice picture! I copied and saved it for future. Hope you don't mind. Jim |
