Happy to be here
![]() Join Date: Mar 2000
My filler neck sux...
It's bad enough having to pay these high gas prices as it is. What adds to my pain at the pump is all the gas that pours on the ground (and my paint) when filling up.
Does any one have a cure for the 73-80 filler neck issues? I would really like to be able to put gas in my 77 without worring about a Haz-Mat team being called... ![]()
Professional Grade
Just pull the filler hose out a little bit, and watch how many liters are goin in, after a while you can hear when it will finish filling and you can slow up the flow of fuel going in. Holding the filler hose just a little bit out keeps the pump from turning off on its own.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
Happy to be here
That sound easy enough, but it won't work for me. I have tried every combo you can imagine. I put it in really far, pull it out, turn it sideways, stand on my head. No matter what I try, it still runs down the side of the truck.
I talked to a mechanic this weekend, and he suggested a filler neck from a diesel powered truck. What year did they start putting diesels in? I guess I'll have to get my sales brochures out. I thought it was 82.... |
i have the same problem with my 83 with its 2 16s. i can get in 10 gallons(if im lucky) and have to milk to other 6 in. i once got 18 gallons in that tank some how...oh well. i ordered a new 20 gallon tank for the passinger side but the biggest problem is how long the fill neck is and how that is almost paralle to the ground. gas likes to flow down hill and i think it was early than that when the desiel came out
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
california fill
Hmm... I used to have that problem. I have put new GM filler neck & vent tubes on both tanks of my truck (and made sure they're installed right, no kinks, etc) and then the gas will flow well.. In california the vapor recovery fuel nozzles are pretty sensitive and will shut off as soon as the tank is full. What I really have a problem with is them shutting off too soon. I have seen people put the nozzle in upside down, for the ones that are the accordian style nozzles, that dont seem to latch into our filler necks.. THOSE are a real PITA. When filling up a 73-87, I try to goto gas stations that have the much simpler nozzles, the one with just a big rubber flap that sits flush against the bedside, no springs, no accordians, etc.. I seem to have the best luck with those.. They dont shutoff early, I dont have to hold them in a certain position to keep the fuel flowing, and they shutoff just in time when the tank is full.. My favorite is USA petroleum, they have these nozzles, and their gas is always the cheapest. I think that all the old fuel nozzles used to be this style and thats what worked when our trucks were designed. The new accordian style like at Mobil, etc just dont work well w/ our trucks. Have you checked the condition of the fuel tank filler neck tube & vent?
pc |
Happy to be here
plumbcut your on the right track. The problem doesn't seem to be with anything being defective. It's more of a design issue. Like you said if it's one older style gas nozzle's it goes a little better because it "fits" better. If it's one of the newer style it doesn't go in well at all.
Regardless of the style it always wants to seep a bit while filling, and cut off too soon. I just need to figure out what year is the best to replace it with, or if the diesel neck is the best answer.... |
On my 85 i have to hold the pump almost all the way out or i cant pump it in full blast and when it gets to the end SPLASH >
On my 87 I have no problem whatsoever. It has dual tanks and I beleive they are original. It was purchased by the original owner in Texas. It has a 305 TBI, I don't know if there is a difference in fillers.
03 Tahoe 72 GMC Super Custom 2500 Custom Camper, my reliable workhorse. Dual gauged tanks, dual battery trays. |
i have the same prob except i can never get more then a little more then half a tank of gas in...thought maybe my gauge was wrong so kept a big emergency bottle of fuel in the bed and kept driving when it got to E and it ran out....so I have not a clue why i can't get a full tank....even if i trickle it in it'll still spit out the side after a bit.
Paul D. '78 C20 Scottsdale 350ci 3 speed with granny gear 14 bolt rearend My trucks are "Car-Guy safe".......which pretty much means death trap in the hands of a normal civilian. |
Happy to be here
Guys I appreciate the comments. Keep in mind I am talking about 73-80 style fuel inlets. They are on the side of the bed, not under a gas door....
#11 | |
Tonawanda 454
![]() Quote:
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!! ![]() 04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011) In the past 30 years about 90% of Fords are still on the road, the other 10% made it home. ------------------- |
[QUOTE=N2TRUX]Guys I appreciate the comments. Keep in mind I am talking about 73-80 style fuel inlets. They are on the side of the bed, not under a gas door....
![]() Is there a difference between the filler necks between 73/80 and 81/87 besides the door? I'm just curious because this is the first time I've heard of this problem with any Chevy. I know it was a common problem with early 70's Ford trucks. They had a flat hose routed horizontally above the frame to the inside of the frame where the tank is located. Looking under my 87 the filler neck can't be more than 18" long and is round with a bit of drop towards the tank. I don't see how this design would cause any splash back. I could leave the nozzle in and let go with mine. My only problem with the design is that they are on opposite sides of the bed rather than on the same side. Filling both tanks is a pain and I need them both on long drives.
#13 | |
You get what you pay for
![]() Join Date: Dec 1999
Mike 1985 Chevy C-10 |
#14 |
Tonawanda 454
i have the exact same problem with my 76GMC LB C1500... spillage is a pain but i just listen for when its close to the top, usually around $40 locally (is $2.029 to 2.099 here).. and there were some specific packages from 78 later thathad doors, it all depends on the package deal... but as far as i know if they have the side inlet they should have the same problem unless they changed it with the doors models
#15 | |
Happy to be here
![]() Guys this has nothing to do with over filling the tank. What I'm talking about is while your putting gas in from start to finish.... ![]() |
#16 | |
79 chevy k20 350/350/205/D44/14bFF 4.56 gears rock ![]() LWB pimer black 01 S-10 ZR2 extended cab 4.3/4L60E/233 3.73 gear 31" DICK CEPEK CRUSHERS |
#17 | |
#18 |
Tonawanda 454
i do hate having to bend over just to hold the nozzle in on my truck. The pumps locally here in FL do not have filler locks i have to hold the handle at all times while filling. I am 6'5 and the filler is just above my knees so it is a pain bending over for $40 worth of gas
