Old 05-31-2004, 11:05 PM   #1
too many
too many's Avatar
Question 700 trans mated to np205???
Im thinking of replacing the 3:08s in my 72 kten with a set of 3:73s. Along with this I want to install a 700 o.drive trans. I think ive seen someone that makes an adapter for this.
Has anyone done this ? / whats all involved? what about gear selector om my tilt column? Thanks!
"My wife says I cant have them all - I tell her I can try!"
too many is offline   Reply With Quote
Old 06-01-2004, 07:54 AM   #2
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
Advanced adapters makes them but there expensive.
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 06-01-2004, 11:38 AM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Keep an eye on the message board on CK5.com and Pirate4x4.com. Every now and then they come up for sale. They go quickly so you gotta be ready to jump on it.
Here's the web site for Advanced Adapters - http://www.advanceadapters.com/
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 06-01-2004, 09:36 PM   #4
jamie72
jamie72's Avatar
i sold a setup to my buddy,700r/205,but the case was cracked on the tranny,if you want i`ll ask him what he wants for it??
jamie
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 06-01-2004, 09:58 PM   #5
1FaastC10
1FaastC10's Avatar
dumb question, why not just go to a 208 or 241? adapters to mate them to a 700R4 are a dime a dozen, as every 4x4 700R4 truck came with one. both cases are lighter, as they are aluminum rather than cast iron like the 205. if im not mistaken both cases offer a lower low range too.
1FaastC10 is offline   Reply With Quote
Old 06-01-2004, 11:49 PM   #6
71swb4x4
71swb4x4's Avatar
Jamie
I am interested in the 700r4/205 if your friend still has it. I PM'd you.
Shawn
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 06-04-2004, 09:22 PM   #7
jamie72
jamie72's Avatar
i talked to the guy today,he still has the combo,he`s wanting 200.00 for the 205,adapter,and the 700r with a cracked case,but it has the adapting tailshaft..
let me know if you guys are interesed in it,too many is first in line,then 71swb4x4.
jamie
jamie72
member #807
www.antlertalk.com
Old 06-05-2004, 12:35 AM   #8
1FaastC10
1FaastC10's Avatar
Originally Posted by 71swb4x4
Jamie
Shawn
way not cool man, a guy posts up inquiring about parts, and you go in to snag the parts out from under him before he has the chance to respond. definitely not a way to make a good impression.
Old 06-05-2004, 12:44 AM   #9
71swb4x4
71swb4x4's Avatar
I am definitely not trying to do that.
That is why I posted on the thread that I PM'd Jamie so that too fast could see.
How else am I supposed to let Jamie know that I am interested? I can't be certain that too fast wants it, and I wanted to let Jamie know somehow in case too fast doesn't want it. So I pm'd Jamie and posted on the thread. I would agree with you if I had PM'd Jamie and then not posted, that would have been way not cool man
Old 06-06-2004, 10:38 PM   #10
8mag
i have 700 and 205 dombo everything but the converter evrything brand new or rebuilt, all the goodies in the 700, new advance adapters kit, tv cable bracket, cooler lines, temp guage flexplate bolts , shift linkage kit, 1500.00..... 8mag@outdrs.net
8mag is offline   Reply With Quote
Old 06-08-2004, 04:59 PM   #11
jamie72
jamie72's Avatar
i have`nt heard from too many,if you are interesed in the is let me know,i`ll hold for one more day,then dibs goes to 71swb...
thanks jamie
jamie72
member #807
www.antlertalk.com
Old 06-10-2004, 04:14 AM   #12
72addict
I think you can if you use a shorter trans output or a spacer between trans and tcase
1957 Cameo
72addict is offline   Reply With Quote
Old 07-08-2004, 03:29 PM   #13
canarykid
700r4 to 205
When converting from a turbo350 to a 700r4 you use the same adapter housing you just have to put a shorter output shaft on the 700r4 advanced adapters sells this shaft for under $100. hope this helps.
canarykid is offline   Reply With Quote
Old 07-14-2004, 12:58 AM   #14
Cethern
What was I thinking??
Cethern's Avatar
When I did my 700/205 deal in my 83 I used a 2in spacer to make up for the longer output shaft. It worked out ok I had to move the shifter back some what and find Metric bolts for the back end of the 700r. I found some all thread as I could not find any metric studs.
Cethern
72 K5 that needs lots of parts..
71 GMC 3/4 4x4 That doesn't need much which is a good thing I don't think I could aford another money pit...
Cethern is offline   Reply With Quote
Old 07-14-2004, 11:40 AM   #15
drink2mny
drink2mny's Avatar
I would have offered this to you but didn't notice the thread..
Here's on I just put on the parts board
http://67-72chevytrucks.com/vboard/s....php3?t=111626
Support The Board
drink2mny is offline   Reply With Quote
Old 07-14-2004, 02:43 PM   #16
bouncytruck
SKINNY TIRES RULE!
208 & 241's aren't nearly as strong as the 205.
bouncytruck 1972 K5
Old 07-26-2004, 11:07 PM   #17
Bhull2
Why can't you just cut the output shaft?
I currently have the NP205 and am converting from the TH350 to the 700R4/4L60 trans and am wondering if anyone has just cut the output shaft to fit. . I am in the process of building the trans, and instead of buying the "custom" output shaft from advance adaptors for $150, I can just cut mine, clean up the splines and that will work.....Any ideas of why it won't? Has anyone else done this?
Bhull2 is offline   Reply With Quote
Old 07-27-2004, 08:22 PM   #18
canarykid
trans adapt
there are not enough splines to cut it.
Old 07-27-2004, 11:21 PM   #19
1FaastC10
1FaastC10's Avatar
well aware of that, but if you've got a truck that you're putting a 700R4 in, its weaker than the 208/241, so you shouldnt have any need for the 205. if you're really concerned with strength, ditch the 700R4 before you ditch the 208/241. they're plenty strong.
Old 08-15-2004, 12:51 AM   #20
86k10
Yeh I have cut the output shaft before, we converted my bros. 82 1 ton 4x4 with a manual 4 speed to a 700. I just used the stock length 4x4 shaft and a spacer block and took about an inch off the output shaft with a cut off saw. The fun part was doing that with the shaft in the trans already. It's been about 10 years since that conversion and if he cannot tear it up no one can. good luck with yours.
86k10 is offline   Reply With Quote
Old 08-15-2004, 07:36 PM   #21
earl87gta
earl87gta's Avatar
Use the advance adapters kit part nummber but get it from summit racing ita abought $50 cheaper threw them.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
