Old 06-01-2004, 01:06 AM   #1
typhoon
Unhappy Fuse block removal
Hello everyone, I have just purchased a 67 shortbed with horrid wiring, in fact, there are 3 different ways to start the truck, (two buttons and one key start ignition switch). I am trying to pull out my fuse block, and am unable to remove it. I have removed the two screws from the inside, but can't figure out how to remove the part potruding through the firewall. Can anyone help me with this?? Thanks in advance!
typhoon is offline   Reply With Quote
Old 06-01-2004, 01:53 AM   #2
jlive68
fuse block
There should be a bolt on the connecter under the hood going into the cab take it out and you should have no problem. if there isn't a bolt there then they may have glued it.
1968 chevy
U.S. Navy
jlive68 is offline   Reply With Quote
Old 06-01-2004, 11:17 AM   #3
crazy4chevs
crazy4chevs's Avatar
Ya, check the bolt its a 7/16. Then just wiggle the connection and it should come apart.
70 chev c10 swb fleet
72 grill, sb 400, 2/4 drop.
68 chev c10 swb fleet
Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C
Classic GM Truck Club of Washington
crazy4chevs is offline   Reply With Quote
Old 06-01-2004, 03:05 PM   #4
typhoon
I think it must be glued, I can see where the bolt went, but there is no bolt, I'll try to pry it apart and see what happens
Old 06-01-2004, 03:11 PM   #5
1971LT1SWBPOSI373
1971LT1SWBPOSI373's Avatar
re
be careful, don't break it............
1971 Shortbed 350/350 w/ Posi-traction 3:73's
1996 Chevy Silverado
TJ in Springfield, Virginia
Likes old Chevy trucks
Drinks Miller MGD
1971LT1SWBPOSI373 is offline   Reply With Quote
