06-01-2004, 08:20 PM | #1 |
Got Horsepower?
oil pressure too low?
after running on the freeway i only have around 7 psi of pressure at idle is this too low?
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit" SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers |
06-01-2004, 08:33 PM | #2 |
"Ochre Ogre"
10 pounds per 1,000 rpm's is operational on a small block chev. Is this something that has changed recently? If it hasn't changed recently and doesn't get any worse you should be fine. It just won't give you the same feeling that looking down and seeing 20psi on the dial.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
06-01-2004, 08:42 PM | #3 |
Got Horsepower?
so i should be alright since it idles at 500 rpm. maybe i'll get an oil cooler to drop the oil temp since the pressure goes up to 15psi after it cools down for a few miles
06-01-2004, 09:50 PM | #4 |
Typical summer time oil pressure. I run 50 weight oil in the summer.
06-01-2004, 10:08 PM | #5 |
I was going to ask what oil you are using, and possibly suggest a weight change (stright 50 wt, or somthing along those lines)
Dan |
06-01-2004, 11:41 PM | #6 |
i get to about 10 at idle after a nice long hard highway run. and im running 20w50 royal purple sythentic but this is with a stock pump from what i understand its totally normal for a sbc with a stock pump so i dont worry about it. no noise and will still peg the gauge out when the engine is first fired
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
06-02-2004, 12:32 AM | #7 |
Got Horsepower?
as soon as i give it throttle the guage pegs. i'm running 10w30 right now and the motor only has 10,000 miles on it. i didn't think that anything was wrong but i just wanted to make sure. thanks for the replies!
