06-01-2004, 10:05 PM | #1 |
blood type; Retumbo
want leg room, need feedback
I have been thinking of stretching cab down the middle about 4 inches. question is what about side window glass? I would prefer to stay with safety glass for , well, safety. then thought of redisigning toeboards & bottom of firewall since they may need modification with the Caprice front chassis & frame "Z". anyone done either of these or am I just way to insane? I NEED LEG ROOM for road trips. I have seen pics of "extended cabs" & just dont think it looks right. JMO
thanks---Todd
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
06-01-2004, 10:44 PM | #2 |
Hmmmm, a "stretched" cab? I can't picture it, but I think it would look different for sure.
06-02-2004, 04:49 AM | #3 |
Sounds like it would be a lot of work (the box would have to be relocated and the rear bumper, but thats the least of your worries) I think I'd just relocate the gas tank (unless you did that already) and look for a different seat bench or buckets that would have a thinner back support to accomadate more legroom IMO. Later Doug
06-02-2004, 07:09 AM | #4 |
blood type; Retumbo
Randy, not long ago I had a thread in photoshop about this, looks cool, barely noticable.
Doug, I have a seat from a '89 F150 which has a thin back & feels wonderful. the seat is touching rear cab wall. I think about 3 more inches would be just right. I like to stretch out while driving. ya know, just thinking. my arms are comfy with seat & wheel position. my legs feel cramped near pedals. maybe I should redo the toe-boards. go sit in a '73-'87 once & you will see what I mean. they have more room. Why?
06-02-2004, 08:36 AM | #5 |
just how tall are you???
https://www.ebay.com/itm/29620574751...mis&media=COPY |
06-02-2004, 08:43 AM | #6 |
More Cowbell....
Might be time to switch over to a 68 Suburban body....and just pull your truck around behind you. (just a thought)
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
06-02-2004, 10:14 AM | #7 |
Here is a comparison shot of the pics that 68C15 was refering to.
The upper has the body stretched about 4-5 inches with the stock length bed still intact. The lower pic is a bit less stretch to the cab (about 3) and the bed shortened, so the wheelbase stays the same. No frame stretch. |
06-02-2004, 10:15 AM | #8 |
Progress = 0%
This one has been stretched (among other things) but I'm not sure how much. Personally, I think it looks out of proportion. I think it'd be easier to buy a different truck
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
06-02-2004, 10:26 AM | #9 |
This one has a stretched cab on the B pillar side.
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
06-02-2004, 10:39 AM | #10 |
Fabricate till you "puke"
I think stretching the B pillar would be a less frustrating mod than trying to stretch the cab & doors, & would still give the room needed. i have also seen a couple extended cabs made from a burb body..... crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
06-02-2004, 10:52 AM | #11 |
The silver truck was stretched 6" through the center of the cab. When you see it in person, it's hard to notice @ first glance.
06-02-2004, 12:32 PM | #12 | |
14.1 @ 96MPH
I would probably go for modifying the floorboards. I think there's room to pull it off down there; I think the only problems you might run into (and none would be THAT hard to fix) would be shift linkage (go to a cable-type or a floor shifter), throttle (again, go to cable), and exhaust (just get creative )
Project1970 - LS1 Swap Complete! |
06-02-2004, 09:25 PM | #13 |
blood type; Retumbo
Jason, all I have to say to that pic is DAMN!!!!!!! someone read my mind. now I need to replace keboard from all the drool. shifter linkage is not a problem. I had the forethought to make a longer column when changing to tilt-telescope-automatic. (dont ask, a LOT of work) spare-replacement cab is cable type throttle (no brainer there) exhaust I am not sure of just yet, may have room.
decision made, I think thanks guys, I love this place. digital multi-faceted brainstorm Todd
