Backup lights in in neutral
I'm getting backup lights, just for a moment (then they go off) in "N" instead of "R". Any electric gurus out there who have a fix for that? Advice is much appreciated.
Thanks.
Resident Curmudgeon
![]() Join Date: Dec 1999
Assuming a column shift automatic, you need to check the backup light switch attached to the base of the column under the dash. It is held on by 2 small screws and there is some slight adjustment you can make at that point. The other place you can adjust some "slop" is in your linkage where it attached to the column on the engine side of firewall.
Alternatively, the switch may be worn out and need replacing altogether. If you remove it, you'll see how it works, its pretty simple.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
14.1 @ 96MPH
I have the same problem with my 700R4 in my truck. I'm told you can adjust the switch but I haven't had a chance yet.
Project1970 - LS1 Swap Complete! ![]() |
