Old 06-02-2004, 10:28 PM   #1
ronh72c10
Question Is this a Locker?
Sorry for the poor quality of this picture, it's supposed to be of the guts of a 12 bolt rear axle someone gave me. I was told it came from a 73 Blazer.
Couple of questions:
It looks like it has some sort of ratcheting mechanism, does that make it a locker?
Will the carrier fit a 72 12 bolt rear axle?
What's it worth, from what I calculated its a 3.07 ratio?
Ron
72 Chevy C10 (rust repaired, starting body work)
72 GMC 3/4ton 4x4
72 Chevy C20 Suburban
38 Ford Tudor Humpback Sedan (from the darkside)
67 Pontiac Parisienne
55 Studebaker Commander 2dr Hardtop (Starliner)
My Youtube channel with Video Updates!
ronh72c10 is offline   Reply With Quote
Old 06-02-2004, 10:39 PM   #2
1972C10
1972C10's Avatar
Thats a gov lock it will fit in a 67-72 12 bolt carrier .
I would say its worth around 50 bucks or so
There not the best in the world but some may think there worth more than i do. Just my opinion
1972C10 is offline   Reply With Quote
Old 06-02-2004, 10:46 PM   #3
ronh72c10
How does it work or how is it different from a locker?
Ron
72 GMC 3/4ton 4x4
Old 06-02-2004, 11:06 PM   #4
Rod
If you really tried to lock that one up in hard driving conditions... you'll be getting towed back... thats a governor style positraction. Those weights in the pic fly outward to engage the postive traction.
Lockers are typically two gears which engage to be a locked unit.
Positraction units for 1/2 tons typically in our vintage came with clutch pack positration... theres some slippage while it engages.
My preference would be a clutch pack posi in a half ton. Its not true lock up but its good in a bind and dosent blow up like the governor type.
Your probably better off selling that governor type to a diff shop... they sell them to owners of blow up governor ones a a lot more than clutch style.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 06-03-2004, 03:06 AM   #5
COBALT
COBALT's Avatar
Yep. Gov. Locker. That's the kind of differential carrier that comes with a pin you can pull and count to 3 before BOOM - grenade.
Detroit lockers look a heck of a lot more solid than that. Literally looks like a solid piece of metal in the carrier with square teeth that tightly fit together with a pin through the center. The idea is when the inside wheel turns at a different speed than the outside the halves come apart and allow the inside wheel to free spin...
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 06-03-2004, 03:56 AM   #6
SweetandLong68
Your UncleBen
SweetandLong68's Avatar
How much do Detroit Lockers run for 12 bolts? $800-900??
What other locking type rearends are out there that can withstand some big HP??
lata
CHRIS
68 C10 shortbed -- Street/Strip
SweetandLong68 is offline   Reply With Quote
Old 06-03-2004, 09:48 AM   #7
72C203503ONTHETREE
72C203503ONTHETREE's Avatar
A Moroso Brute strength diff is not a true locker but is a very strong limited slip. It has twice the clamping force than a stock 12 bolt limited slip and the case is much stronger. I had one in my 66 Malibu and it would always hold tight, it almost is too much for the street though on a car. They make them for 10 and 12 bolt car rears and the 12 bolt truck rear for around $450-$500 plus installation costs.
72 Chevy C20, SOLD (Dang it.)
09 Challanger RT six speed in all black.
74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power.
73 C10 long bed, 350/350 combo, nice shape.
72C203503ONTHETREE is offline   Reply With Quote
Old 06-03-2004, 11:20 AM   #8
LONGHAIR
I'm on the same bandwagon. Those "Gov Pop" diffs are worthless. Any kind of horsepower or tires larger than stock will kill it qiuck. I've replaced dozens of them. They generally spit out little parts that will ruin your ring and pinion at the same time.
LONGHAIR is offline   Reply With Quote
Old 06-03-2004, 12:50 PM   #9
COBALT
COBALT's Avatar
The Detroit Locker isn't made any more. They used to go for about $550+ new. Now you'll have to do some research to find a new equivalent. Since I'm not in the market (and haven't been since I bought mine 2 years ago) I don't have any info for you. You might want to ask the 4x4 guys...
Seattle, WA.
Old 06-03-2004, 12:57 PM   #10
ronh72c10
Thanks for the info guys, it doesn't sound like it's worth putting in the truck I'm building for my wife.
I'll put it up on the board for $50 and somebody who already has a gov lock can have a spare.
Ron
72 GMC 3/4ton 4x4
Old 06-03-2004, 04:44 PM   #11
1969 GMC
1969 GMC's Avatar
Cobalt,
Tractech no longer makes a detroit locker/no-spin for the Eaton H0 axles, but they still make them for just about every other axle. They also make the detroit SoftLocker, which is supposed to be the same as an original but quieter, as well as a few other traction aiding devices.
www.tractech.com
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 06-03-2004, 07:46 PM   #12
SweetandLong68
Your UncleBen
I was getting ready to say...
I just couldn't believe that they quit making the Detroit locker...That would be insane! haha...My buddy has one in his 70 Camaro (with Ford 9" rearend) and it hooks and you know it is working...
lata
CHRIS
