Old 06-03-2004, 07:19 PM   #1
setandreel
setandreel's Avatar
Help on front hubs?
Hey all,
I have a 87 silvarado 4X4 just checked my auto hubs and the small bearing on the spring is gone, don't know how long, have not used 4X4 since Feb. I am leaving on Sat. on a 720 mile trip. Question, is my transfer case full time or part time? Every one I have talk to say's 208 and it looks like a 208 but I checked the tag and it say 203? Very confussing. Could be a miss print in the stamp. I want to put warn hubs on and I think it would be pretty simple if it is not a full time transfer case. If it is full time do I need a kit of some kind to make it part time.
Thanks in advance
Mike
setandreel is offline   Reply With Quote
Old 06-03-2004, 08:03 PM   #2
Blazer1970
Blazer1970's Avatar
Your '87 has a 208 unless someone has changed it. It is part time. The last year the 203 was used was 1979.
Blazer1970 is offline   Reply With Quote
Old 06-03-2004, 08:28 PM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Does it have a slip joint in the rear of the transfer case? If it does it's a 208 as the 203s would have a yoke.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 06-04-2004, 12:45 PM   #4
justinf
Is your transfer case aluminum? The 208 case is aluminum, the 203 is cast iron.
1981 CJ7 - 350TBI, sm465, np205, D60, 14bolt, 5.13s, detroits, 38.5 SX's
1998 Z71 extended cab
1998 Tahoe
2001 Tahoe LS - FOR SALE - $18,500
justinf is offline   Reply With Quote
Old 06-04-2004, 06:32 PM   #5
Devil'S Ride
Also, you cant use manual locking hubs if its a 203 unles you change it with a part time kit. Like mentioned above, look for a slip joint or yoke at the rear of the TC.
Good luck!
The Devil
1983 ONE TON 454/400/208 11" of lift on 44's
Devil'S Ride is offline   Reply With Quote
