Old 06-03-2004, 08:22 PM   #1
406cid70Chevy
Alternator plug question...
The plug that goes in an externally regulated alternator (I don't know the name), it looks like it doesn't fit on my alternator correctly. I'm wondering where I could locate a correct fitting plug/harness. I've looked in part stores but haven't found any. Or if it comes down to it...could I just cut off that plug and put on a female connector for each wire? Would there be any harm in doing that? Here's a pic to explain what I'm talking about...the plug is really loose and will sometimes just fall off.
406cid70Chevy is offline   Reply With Quote
Old 06-03-2004, 08:55 PM   #2
Bowtie67
Bowtie67's Avatar
you could put spade connectorss on there, just make sure they have insulators to stop them from hitting anything, or you can hit the junkyard up and see if you can find anything there, just the pre internal regulator setup, or better yet put an internal regulator setup on there and be done with it. You will also be able to put a higher amp alt on for the ignition and halogen headlights.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
Old 06-03-2004, 09:01 PM   #3
Gordo
If you can locate another plug, perhaps from a doner vehicle at a junk yard, you can take a small flat object, such as a very small screw driver that you would use to repair eye glasses, slide it into the backside of the plug on each wire and release each terminal from the bad plug, then snap the connectors back into the new plug. This way you won't be cutting and splicing any wires.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 06-03-2004, 10:11 PM   #4
68C15
blood type; Retumbo
68C15's Avatar
just looking closely at pics. niticed that on the "R" side there is something keeping plug from going all the way in & latching. see the damage to plastic in the 3rd pic?
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 06-03-2004, 10:25 PM   #5
406cid70Chevy
ah yes, thanks for noticing that. Turns out the male connectors on the alt. had been going in on the wrong side of the female connectors and it wouldn't go in far enough to latch. Problem solved, thanks lol.
