sold
tranny leaking ?'s
the tranny is leaking on my 89 burb. i havent got under it yet to check it out. any common leaking spots i should look for?
07 Rubicon, 2" lift,35's on some bling'n 20"s, warn winch. (20's for sale, 5on5) looking for 73-87 crew cab with 8' bed,2wd,PM me if you see one around |
Slots go on anything!
Your truck should have the improved boot seal around the dipstick tube. Some of the older ones were sealed by an O-ring. Check the pan gasket, o-ring around the TV cable, O ring around the shifter inlet (for lack of a better term) ot the front and rear seals.
1974 Jimmy- 5.3/4L80e/NP241 |
sold
well i know its not the rear seal cause its ends up leaking off the crossmember (2wd) im hoping its something easy like the filler tube
