Old 06-03-2004, 11:14 PM   #1
68jimmy
68jimmy's Avatar
Need help with drive shaft after engine/tranny swap
Well I finally swapped out the original v6/3-speed in my 68 gmc lwb to a 350/350 combo. The engine is located in the forward position and the tranny has the shorter 6" tail shaft. Now to the problem, I went to install my fron drive shaft and discovered that it is about 3" inches to short. If anyone has done a similar swap how much was needed to be added to to the driveshaft length? Or was the yoke from a similar setup longer? Or was there a front driveshaft made specifically for the v8/350 combo that is longer? If so does anyone have a length that I should be looking for? I could go rummage around one of the local yards and see what I find...
thanks.
68jimmy is offline   Reply With Quote
Old 06-04-2004, 07:28 AM   #2
cdowns
cdowns's Avatar
you just need a new driveshaft for a v8 auto setup , try the parts board i'm sure guys got them cheap
