06-04-2004, 04:45 PM | #1 |
\/ My Loves \/
Big problem :(
Well we started puttig the cam in today. Came into a big problem. first off were runing a Summit 383 Crank, 6 in. Scat Rods, and a Comp cam .630 lft cam. Well the first 3 lobes on hte cam are hitting the the #1 and #2 connectings rods. Is that b/c of the crank having to much stroke? Wat would the problem be? The cam spins freely but when spined w/ the crank it hits. Now thats at top dead center on number. Will adv. and/or ret. the timing get rid of this clearence problem. Or would it have to the with the cam to crank center line? Right now we 4 1/2 in. Center line from cam to crank. I have no clue wat so ever on wat the problem is. I figured, it would slid in no problem wat so ever. But, wat yalls advice on this problem? Is the cam to big, is my Crank, rod to cam combo wrong. The block is outa of an 86 Burb, and its a 1 piece rear main. Help me guys!! Thx
Tyler
78' Silverado - Blue - (In a Coma) 04' Silverado -Red- 383 Stroker in progress for the 78'!!! |
06-04-2004, 05:13 PM | #2 |
www.73-87chevytrucks.com
You need a small base circle cam.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
06-04-2004, 05:16 PM | #3 |
Maybe you can get away just radiusing the bolt heads and a small section of the big ends on those rods,from what i remember (and i have never used Scat rods so I may be wrong) they have quite a bit of meat there and can be radiused just fine. If not, do as captkaos says and get a small base circle cam.
06-04-2004, 05:19 PM | #4 | |
\/ My Loves \/
06-04-2004, 05:26 PM | #5 |
Don't you know what the base circle of the cam is? It's the circle of the cam where there's no lobe, so the section the lifter rides when the valve is closed. A small base circle cam has, as the name iimplies, a smaller circle allowing more clearance. Lift is still the same as it's just the amount the lobe lifts from the base circle.
This should clarify it a bit: Last edited by TwinTurbo; 06-04-2004 at 05:34 PM. |
06-04-2004, 05:39 PM | #6 | |
\/ My Loves \/
Tyler
06-04-2004, 05:41 PM | #7 |
Because of the smaller base you will most likely need longer pushrods, be sure to check valvetrain geometry.
06-04-2004, 05:55 PM | #8 | |
\/ My Loves \/
Tyler
06-04-2004, 06:02 PM | #9 |
First of all you will need a pushrod lenght checker tool. The geometry is easily checked, you can do it for 1 valve or all if you want to be real precise. Just watch the rocker tip (or roller if you are using that) and see if it starts out at the inboard side of the valve stem and travels to the outboard side without getting close to or on the edge in both extremes of travel (valve open & closed), that's all.
Why do you need a new cam drive setup? |
06-04-2004, 06:08 PM | #10 |
with that size cam there is a chance that you still will have to clearence the rods even with a the new small base circle cam
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
06-04-2004, 09:50 PM | #11 | |
\/ My Loves \/
06-04-2004, 11:57 PM | #12 |
Tyler, what heads are you running on that engine?
06-05-2004, 01:59 AM | #13 |
\/ My Loves \/
Brodix, Dont have the specs rdy at the time I'll post them up later. They are fully cnc ported but not polished. And they have been on a flow bench and I'll post that up as well.
