Old 06-04-2004, 05:34 PM   #1
muscletruck
reving so high
hey guys and gals when i drive my truck to work its reving really high when im on the highway and im only going about 55-60.... 454/ th400 trans... i have no idea what the gear ratios are in the back... but anyway... i think the tranny might be getting old and it may need a rebuild... it does tend to slip occasionally but only when i am reving about 2000 rpms from a stop... but the main thing is the engine rpm.... i dont like making my truck scream for 20 minutes straight just to get to work...not fun for me or for gas... im gonan swap an ovrdrive but i cant afford the driveshaft cut and balance(moneys really tight)... have everything else.. so ya.. what should i do ya'll.... thanks for the help
i think i found me truck!
78 Crew Cab Dually
454/TH400, Dual Flows, Edelbrock Intake, Cam, Lifters, Billet Grill, K&N Airfilter, Grant Steering Wheel, A/C, soon to be power windows and locks, lots of plans for this...
....gas prices go down please
muscletruck is offline   Reply With Quote
Old 06-04-2004, 05:42 PM   #2
Russell
Professional Grade
Russell's Avatar
Go to a wrecking yard and look for a truck with a TH350 with a 9" tail, or 700r4 and take it's driveshaft, should be very cheap, and should technically be a bolt up from what I understand
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 06-04-2004, 05:47 PM   #3
PHOENIX
When I was going to swap a 700r4 inplace of my 465 (manual) I got a driveshaft from a suburban that had a 700r4 and it was the perfect length.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
