06-05-2004, 05:45 AM | #1 |
What I drive
Timimg Question
The 85 Silverado that I drive to work seems to lack power when the go pedal is mashed to the floor and it also rattles......valves that is. It has an older 350 in it and seems to run good until the gas pedal is mashed to the floor. I am thinking the timing is off. I have not checked it. I have read that base timing at idle needs to be around 10 to 12 degrees BTDC. And forgive me for the stupidity but if I were standing in front of the truck looking at the damper trying to set timing where is BTDC to the left or right of TDC? Or another way to look at it is above or below if looking at the damper from the drivers side fender? Been awhile since I've owned a chevy that I have had to work on. Thanks!
1986 Chevy Crew Cab Dually(Choo-Choo Conversion) 2006 Chevy Equinox |
06-05-2004, 11:08 AM | #2 |
the timing mark will be to the left of the TDC mark as you're looking straight down at the timing cover. if your cover is stock, TDC will have a larger notch in it.
06-05-2004, 04:25 PM | #3 |
Right turn Clyde
The left side of the picture is the passenger side, the right is the driver side.
Let me know if that helps you understand it better. If not I will try something else.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
06-06-2004, 11:55 PM | #4 | |
What I drive
06-07-2004, 12:08 AM | #5 |
Professional Grade
Heeeyyyy... I reconize that harmonic balancer, and that filthy waterpump too!!
Its black now
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
