Old 06-05-2004, 03:22 PM   #1
66nova383
Question fuel filler in bed corner
lets try again, anybody got pics and info on putting fuel filler in left rear bed corner ? any info or ideas would be great. thanks
66nova383 is offline   Reply With Quote
Old 06-05-2004, 03:34 PM   #2
67cst
i love summertime
67cst's Avatar
sorry i cant help but i need one too, 1 1/4 inch in diameter for the hose to slide on, im having no luck finding one, its to the point where id offer a reward for someone who could help out!
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 06-05-2004, 04:20 PM   #3
ryan68
Certified Chevy Man
ryan68's Avatar
As for the 1 1/4" diameter filler, I needed a 1 3/8" for my tank and had a filler tube from an 87 suburban which was 1 1/2" I believe. I went to checker/autozone and found an exhaust reducer piece that fit a 1 3/8" hose and weld that thing on the filler tube. Just a thought.
68 Chevy CST (327,TH400) 3/5 drop lots of fun stuff
71 Suburban 4x4 (350,TH350) 7" lift 37's, D44/14 bolt and other sorts of goodies, lockers front and rear, flexes 40", 895 RTI score
Check out my web site!!! http://www.geocities.com/cst68chevy/
ryan68 is offline   Reply With Quote
Old 06-05-2004, 04:26 PM   #4
Mudder
Mudder's Avatar
Here is mine using a copper elbow that was brazed onto a marine filler. Works, but the only draw back is you can't put gas in real fast. It works ok tho.
Mudder is offline   Reply With Quote
Old 06-05-2004, 04:43 PM   #5
67cst
i love summertime
67cst's Avatar
hey mudder i wish i had a body lift i could dosmoething like that! i have no room for adaptors so i need something with a 1 1/4 off the get go
Old 06-05-2004, 04:55 PM   #6
Mudder
Mudder's Avatar
I can understand where you are coming from. I dont really have that much fall and I have the body lift. I dont see how its done on a truck with no body lift. The hose will not bend either, so forget that.
Gonna go make use of mine right now and spend a bunch of money.....
Old 06-05-2004, 06:07 PM   #7
66nova383
My thought is to make a box the same size dimensoins as the stake pocket but only half the height. Then attach it to the stake pocket and have the fill cap at the top of this stake pocket extention.That way it should be elevated enough to make the fuel flow down to the tank real easy. what do ya think ?
Old 06-05-2004, 07:20 PM   #8
ryan68
Certified Chevy Man
ryan68's Avatar
I have no body lift and my filler is about 6" above the bedfloor on the driver's side inner bedside. My tank is also so high the rubber to connect the filler hoses is about 1/8" off the bottom of the bed. I don't understand how you don't have room for an adapter. I cut off part of the original filler and welded the adapter on and it was still shorter than the original.
Old 06-05-2004, 07:21 PM   #9
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I think that there is a how to on the main page of gmc paul's web site that has to do with an s-10 type filler in the corner of the bed...
Old 06-05-2004, 07:24 PM   #10
67cst
i love summertime
67cst's Avatar
mudder-its hard to explain, the spout comes off the tank at an angle, the hose slides over it and comes up to the bed, there isnt enough for an adaptor so i need a type of filler that will mount flush in my bed then join up with the hose that would be maybe 4-6 inches long at the most then the tank spout is there....
Old 06-06-2004, 02:00 AM   #11
Mudder
Mudder's Avatar
Mine mounts flush in the bed. At some point u will have to have a 90 or a 45 bend . I will try to measure the fitting and filler you see on mine tomorrow. I'm pretty sure its not more than 4 inches it that fromthe bottom of the floor.
Old 06-06-2004, 11:46 AM   #12
71swb4x4
71swb4x4's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...category=10076
I am not totally sure what you need but this may help. It will get you a 90 degree.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 06-07-2004, 10:25 AM   #13
70short
Thumbs up
Try www.aluminumfuelcell.com He has this in the bed MOD. I beleive he sell's A kit. I see him posting on www.myoldtruck.com every now and then. This is what I will be doing when I get to this point. good luck!!!
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 06-07-2004, 12:53 PM   #14
PrimeredThunder
Back from the Dead
PrimeredThunder's Avatar
Do you mean like this? This is my setup in my truck...it uses a 69-72 Blazer fillerneck, and a fabbed up bracket. The hoses go between the top of my frame and under the bed floor to my tank under the bed. The truck is a 72' 2wd SWB. Let me know if you need anymore pics.
Kenny
The only Carb that matters to me is the one under my hood!
Salem, Oregon
PrimeredThunder is offline   Reply With Quote
Old 06-07-2004, 03:17 PM   #15
70short
Talking Cool
Nice job PrimeredThunder!! Can you post more info on that filler neck project PLEASE!! Dimensions, Pictures. What did you use to attatch the filler neck to the tank inlet (hose type)? Does the blazer filler neck come with the vent hose next to the filler? Does the blazer filler neck have A flange on it to attatch to the FAB'ed panel? Sorry for all the questions but I really like that job and really interested!! THANK YOU IN ADVANCE!!!!!!!!!!!!!
Gary
Edel 600 cfm carb
HEI
shorty Headers
4/2 Drop
"CHEVY RULES"
Old 06-07-2004, 04:03 PM   #16
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Arrow
Wasn't there also a way to put it behind ur left rear tail light, I thought I
saw a post recently where people where doing this as a option also ......
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 06-07-2004, 04:18 PM   #17
70short
I am looking for the in the bed filler myself. Answer to your question there are tail light and marker light filler MODS.
Edel 600 cfm carb
HEI
shorty Headers
4/2 Drop
"CHEVY RULES"
Old 06-07-2004, 05:49 PM   #18
jay6891
Car Knocker
jay6891's Avatar
here is mine that came off a 91 mustang. forgot to prime it though, now I have to regrind it. I just went to the local muffler shop and had them make me an adapter from 2" to 1 3/8". I broght it home and welded it to my new filler. I think that they charged me $5.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 06-07-2004, 05:59 PM   #19
68C15
blood type; Retumbo
68C15's Avatar
lets hear more about the tail light filler. I havew a general idea, but would like ti hear more or see pics.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 06-07-2004, 10:14 PM   #20
special70gmc
special70gmc's Avatar
mines just muffler pipe and rad hose
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 06-08-2004, 12:21 PM   #21
PrimeredThunder
Back from the Dead
70short - I will get you info later tonite, I'm at school now, but I'll get you some better pics and measurements. heres a few old pics i found with the bed off
Salem, Oregon
Old 06-08-2004, 05:25 PM   #22
dallas71
dallas71's Avatar
more info please...
dallas71 is offline   Reply With Quote
Old 06-09-2004, 11:29 AM   #23
ryan68
Certified Chevy Man
ryan68's Avatar
Primered Thunder, I did exactly what you did, but customized that "Auxillary Fuel Tank Filler Panel".
If anyone can shoot me their, e-mail, I'll send them a pic of what I did, cause I can't figure out how to reduce the size of the pic without making it ridiculously small.
My set-up is an 87 suburban filler tube and I cut the vertical tube in half, rotated it around 180 degrees and welded it back on.
