![]() Join Date: Feb 2001
Avoiding Tweaking Blazer Body??
I've heard people talk about tweaking the body of their Blazers out of alignment before. What are the dos and donts of replacing body panels and installing patch panels on a Blazer. For example, If I keep the top on my Blazer and keep the tub on the frame, can I pretty much remove any body panel I want to and cut out any rust and weld in new patch panels without worrying?
The main reason I ask is that I've got the top on my Blazer right now and the tub is mounted to the frame. The tailgate, doors, etc. are all off the truck. I need to remove the rear cross sill that runs across the back just under the bed because I have some rot that has happened along the rear of my bed due to moisture being trapped in between the rear sill and the bed. Can I do that without fear of tweaking anything? Do I need to rig up some bracing or anything? Thanks everybody.
'72 Chevy Blazer |
Just like to part out trucks!!
I'm curious too, I have to put new mounts on mine, top is coming off too.
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
I replaced the body mounts, pillar ends, inner and outer rocker panels, and some patch work on the floor. I put my top on before I started cutting, and I still got some minor movement. It was not enough to cause any problems, but next time I would weld in temporary bracing.
The LuvShack Garage
A few weeks ago I put out a thread about some braces I saw in someone's
blazer pic's, I have yet to get a response from the correct person. Removing body off the frame and I want door braces and a tailgate brace. I guess if I could get factory spec's I could build some, but I don't want to go off of what I have now because rocker boxes are junk and windsheild moves when you open the doors just slightly, I to could also use some advise on this....
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
Jimmy72Custom, did you have your tub on the frame and you still got movement like that??
'72 Chevy Blazer |
I had the tub on the frame. With the fenders off I jacked up the body one side at a time and replaced the body mounts With the front fenders off, and the rocker panels cut out, if the cab supports and pillar ends are rotten, the windshield frame / firewall will move freely. Putting the top on and checking door clearance before cutting out any metal will get you by. If you are taking the tub off, I think I would weld in temporary supports to hold the fire wall in place if metal needs replaced.
Just my opinion:-) ![]() |
