Old 06-06-2004, 02:12 AM   #1
doughby82
doughby82's Avatar
2000 silverado fuel pump?????
my 2000 silverado is getting harder to start.i have to pump the gas to get it to start now.fuel gauge reads when it wants to.also i have a misfire code in cyl 4.im guessing my fuel pump is going south.how do i determine what fuel pump i need .i read somewhere i need to check engine vin for a certain letter.that will determine if i need a tcu or tcf fuel pump,whatever that means.by the way its a 2wd 5.3 auto.HELP any help would help,thanks again
springfield illinois
2003 custom (harley)built from scratch
68 swb
doughby82 is offline   Reply With Quote
Old 06-06-2004, 11:15 AM   #2
Josh
He's got mean nasty FANGS!
Josh's Avatar
Check the 8th digit of the vin, if it's a Z it means you have the bi-fuel 5.3 with the notorious fuel pump. Z motors tend to eat fuel pumps like candy, GM is supposedly "working on a fix" but they still havent released a redesigned fuel pump. It's fairly easy to change, all you have to do is remove 8 bolts from the bed, unplug the wiring at the rear, and unbolt the filler neck from the bed, then get 3-4 guys, lift up the bed and slide it backwards, setting the front of the bed on the tires, and the rear of the bed on a 55 gallon drum. should be able to do it under 2 hours that way, if you have a tool box or something heavy in the bed you'll have to drop the tank which doesnt take too long, but is more annoying to do. If your fuel gauge is reading very erratic, and hard to start etc. I would guess you have a Z motor, for the misfire, i'd check the plug/wires on that cylinder, it could be many things. Hard to say without a tech2 hooked up.
2004 K2500 Burb
1999 C3500
1985 Cutlass Supreme
1969 C-10
1967 C-10 Panel
josh@67-72chevytrucks.com
6772chevycom@gmail.com
Josh is offline   Reply With Quote
Old 06-06-2004, 11:40 AM   #3
doughby82
doughby82's Avatar
digit eight is a t.as far as the misfire i already changed the plugs and wires
68 swb
Old 06-06-2004, 02:12 PM   #4
Josh
Josh's Avatar
Is the code current, or is it a history code? Can you feel the truck missing?
2004 K2500 Burb
1999 C3500
1969 C-10
1967 C-10 Panel
Old 06-06-2004, 02:59 PM   #5
doughby82
doughby82's Avatar
i just bought the truck last week,it was there when i got it.yes you can feel it missing when its idle.but its smooth as a babys but when driving,also when i got the truck the code i pulled was a multiple miss fire.now its just number 4
68 swb
Old 06-09-2004, 08:08 PM   #6
Josh
Josh's Avatar
I'd check the plugs and see if they're fouled, also wiggle the wiring harness connectors in the center of the valve cover by the coils, thise wires tend to break pretty often.
2004 K2500 Burb
1999 C3500
1969 C-10
1967 C-10 Panel
Old 07-04-2004, 05:59 PM   #7
RemoteControl
It is far more easy to drive the truck till gas tank is low on full, unhook the wires and fuel lines, then undo the 2 straps and drop the tank then to remove the bed, from experience.
PEOPLE THAT THINK THEY KNOW EVERYTHING ARE PARTICULARLY ANNOYING TO THOSE OF US THAT DO !!
Dropped 93 Chevy Std Cab, 454 SS conversion, 20 in Centerlines, Wrap Around Ground Effects
RemoteControl is offline   Reply With Quote
Old 07-05-2004, 01:51 AM   #8
doughby82
doughby82's Avatar
thanks but no it isnt.it takes about 10 min's to remove the bed
68 swb
