Old 06-06-2004, 12:06 PM   #1
Rod
Lock cylinder removal with no Key?
How do you go about removing the lock cylinder on the column from a 79 truck column with no key? I suppose I might as well ask if there is a difference between tilts and non tilts also... would like to know both ways if there different.
I read this posted link on a typical type answer, but you would still need a key with this manner of disassembly. So I dont think it will work without a key. I got a parts truck with no keys. Need to unlock steering coulmn to move it around.... but I got it running now also... so would like to drive it around besides push or tow it.
Beats trying to drive it with a busted column... a set of vice grips for a steering wheel and messing around with the constant stalling and starting of a parts beater. LOL
http://home.t-online.de/home/O_Scholz/steering.html
Thanx, Rod
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 06-06-2004, 02:36 PM   #2
1FaastC10
1FaastC10's Avatar
remove the steering wheel, the lockplate, and the TS switch. there is a screw that holds it in. no key needed.
1FaastC10 is offline   Reply With Quote
Old 06-06-2004, 10:13 PM   #3
Rod
The 79 column does not have a screw like whats in the posted link above... so I couldn't do it that way. Still in that linked post you had to have the cylinder in the run position for it to come out also. Must be another way.
I'll eventually grab a tilt coulmn in my travels to the scrap yards... but if I find another column wih no key, I would still like to know how to get it out.
Rod
Old 06-06-2004, 11:29 PM   #4
TROYLV
1/2 Inch Drill Bit. Drill Center Of Switch And Turn To Any Position With Screw Driver
troy wilson
TROYLV is offline   Reply With Quote
