Old 06-06-2004, 04:31 PM   #1
406cid70Chevy
1970 th400 downshift solenoid questions
The downshift solenoid is in the transmission but no wire is hooked up to it so I have no clue where the wire should go. In 1970 C20's with the th400 was there a switch on the gas pedal that indicated throttle postion or was it on the carb? Here's a pic of a 71-72 gas pedal assembly, should I have this in mine, because I don't.
406cid70Chevy is offline   Reply With Quote
Old 06-06-2004, 04:40 PM   #2
john
member #16
john's Avatar
I don't have a pic but it was on the carb. John
john is offline   Reply With Quote
Old 06-06-2004, 05:28 PM   #3
406cid70Chevy
Did the wire just plug in somewhere on the carb and that's it, or is there more to it?
I don't have a detent cable either, did these trannys(th400) come with one in '70?
Old 06-06-2004, 05:58 PM   #4
neonlarry
neonlarry's Avatar
Quote from another website:
"The TH400 uses an electrical slide switch, which is controlled by the throttle linkage."
Advert with pic for Hurst kickdown switch.
http://www.firewheelclassics.com/det...duct_id=TRN605
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 06-06-2004, 06:19 PM   #5
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
You have to have a wire running to ignition unfused also. The stock set up has a wire that plugs into the cigarette lighter spot. Then it has a pig tail that the T-400 switch plugs into. The front spade on the kick-down switch goes to the transmission and the rear spade goes to the 12 volt soarce. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 06-06-2004, 07:01 PM   #6
406cid70Chevy
I still have the pig tail in the cigarette lighter spot. So, all I need is a wire that runs from the kickdown switch to the pigtail, right? I already have my 12 volt ignition wire in the ign. unfused slot. Here's a pic of from what I understand how it should hook up.
Old 06-06-2004, 09:10 PM   #7
JimKshortstep4x4
Smile
Here is a picture of what the 70 and older kickdown switch looks like.
Jim
Old 06-06-2004, 10:44 PM   #8
Classic Heartbeat
If you look at the picture of your kick down switch next to the carburetor. The 2 plugs that you have yellow wires going to, the one front (closest to radiator) runs down to the transmission. The one in the rear (closest to the firewall) runs to the extra plug in the pig tail for your cigarette lighter. WES www.ClassicHeartbeat.com
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
