06-06-2004, 06:04 PM | #1 |
PROJECT 7DEUCE
Mini tub's ??????
Those of you who have bag's or a 6-8'' rear drop do your inner bed wheel well's still fit???? I was gonna mini tub the truck using stock well's but I am looking ahead to bag's and wondering if the are gonna rub on a wheel from 17'' to 20'' need some feedback on this thank's guy's ....If you fabbed or made the stocke well's work pic's would be great...
06-07-2004, 12:29 AM | #2 |
PROJECT 7DEUCE
Ttt
Ttt Ttt Ttt |
06-13-2004, 10:49 PM | #3 |
If the rear tire is over 28" tall, then @ 8" drop you will more than likely rub the top of the tubs. With 295/40/20's on 20x10's w/@ least 8" drop, mine rubbed & required raising the floor/tubs to clear.
06-13-2004, 10:51 PM | #4 |
PROJECT 7DEUCE
Thank's for the reply do you happen to have any pic's????
06-14-2004, 06:59 PM | #5 |
Here's a shot of the pass side. . .....
Notice the bedfloor where it meets the bedside. It's now 3" above the lip of the bedside.
06-14-2004, 07:07 PM | #6 |
W/the tubs installed . . ....
You can see the tops of the tubs are now even w/the factory body line of the inner bedside. It's not really noticeable (just look @ a factory bed to see the 3" difference).
06-14-2004, 07:14 PM | #7 |
From the front . . ....
Here's another angle that shows both the top & bottom against the factory bodyline of the inner bedside. My plan was to use a spray in bedliner to help 'hide' the original lower bodyline. But, I'm kinda' anal so I might just section the inner bedside altogether to keep the lines as GM intended . . .... minus 3".
06-14-2004, 11:11 PM | #8 |
PROJECT 7DEUCE
That's is just what i was looking for that is some killer work you do... I am just guessing that you raised the frame mout's up to meet the new floor or is the truck body dropped???
06-14-2004, 11:53 PM | #9 |
Spacers made from 1" square tubing.
06-22-2004, 02:00 AM | #10 |
Question guys
on a 67-72 shortbox fleetside what would be the widest tire you could go with?, saying you drop it roughly 4 inchs from stock, using whatever back spacing required..I know a 295 fits know problem. |
06-23-2004, 09:25 PM | #11 |
Wow That's Frigging Nice Work ! I love the way you finished the floor. I understand the hours involved in doing that kind of work.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
06-23-2004, 10:39 PM | #12 | |
06-24-2004, 01:51 AM | #13 |
Oh ok! yeah cause my dad had 16.50' hoosiers on his truck, they didn't come close to rubbing the frame at all. I was just curious without tubbing it out,just a stock fleetside box, what size tire you figure would fit?, like 305 or maybe a 325?
Thanks |
06-24-2004, 07:33 PM | #14 |
Lowered 4"? . . ..... 325mm max on a 10" wheel. My guess is that would still want to buzz the outer wheel well lip.
06-25-2004, 08:49 AM | #15 |
More Cowbell....
406 SBC, I had a '69 fleet side that was lowered roughly 4 inches and I was running a 305 without rubbing. I don't remember if the rims were 10s or 12s (I am thinking 10s for some reason).
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
