Old 06-06-2004, 07:04 PM   #1
ocbaud
Garage Queen Material
putting drum back on?
okay, we changed the brake cylinder and brake shoes, got it all put back together, but.... we cant get the drum back on there. the brake shoes are expanded out to much to allow the drum to be put back in place.
ocbaud is offline   Reply With Quote
Old 06-06-2004, 07:07 PM   #2
Prerunner1982
Prerunner1982's Avatar
take your parking brake off numbnuts!
Prerunner1982 is offline   Reply With Quote
Old 06-06-2004, 07:12 PM   #3
ocbaud
it is stupid face
Old 06-06-2004, 07:15 PM   #4
phantom dually
Project92 SWB stepside
phantom dually's Avatar
there is a adjuster that you will need to run back in to get the drums back on.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 06-06-2004, 07:18 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Yeah like phantom said. There is an adjuster that goes between the shoes at the bottom. You have to push the adjusting arm out of the way so you can turn the wheel with the teeth on it. Adust it all the way in, and push the shoes in. Now your drum should go on just fine...
Old 06-06-2004, 07:40 PM   #6
ocbaud
okay, STFU jon!!!
i swear that i took the parking brake off!!! somebody must have put it back on!
new problem, maybe....
my dad doesnt seem to think its right, but the driver's side brake is doing the same thing, and we havent worked on it yet.
we were bleeding the brakes, and i think we got all the air out, but anytime i hit the brakes, no matter how hard i hit them, the rear brakes do not move at all. it was getting fluid, cause we did bleed them, but none of the springs or shoes or cylinders will move.
does the car have to be running or driving for them to work?
Old 06-06-2004, 08:15 PM   #7
Prerunner1982
we really need some of the smiles from ck5 or pirate4x4.... i have the perfect one for you!
hope your propotioning block is good, check the lines, sounds like my tbird, couldnt get the master cylinder to bleed, but it wasnt the first on my list of things to do.
Old 06-06-2004, 08:17 PM   #8
ocbaud
well, if we hit the brake. fluid WILL come out of the bleeder valve. so its getting fluid and stuff, but the things just wont move.
Old 06-06-2004, 08:23 PM   #9
Prerunner1982
my tbird would bleed too, with fluid and everything, but the brakes still didnt work........
Old 06-06-2004, 08:24 PM   #10
ocbaud
sooo..... what does that mean to me? i need a new proportioning valve??? or do i need to do what mike did?? some day...
Old 06-06-2004, 09:26 PM   #11
Prerunner1982
i figured mine was the booster/master cylinder, but i have yet to get done so i am not sure yet.
Old 06-06-2004, 09:59 PM   #12
ocbaud
well, we got it all done, it will brake, but not very well. it is actually braking worse. i think we got all the air out, we did bleed it about 3 times on each side.
but it makes a whoooshing sound whenever i hit the brake
Old 06-06-2004, 10:11 PM   #13
Prerunner1982
how does that go again?
Old 06-07-2004, 01:39 AM   #14
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
That WHOOSH sound is your power brake booster leaking. Time to replace it and the master cylinder at the same time.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 06-07-2004, 02:05 AM   #15
ocbaud
thats what i figured
its been doing it since the engine has been in, and probably back before october when we pulled the old one
hmm..... gets me thinking though, i wonder if i should just go ahead and get all the parts mike got so i can start on the disc convertion too, since i plan on doing it that way anyhow.
either way, where is a good place to order a booster/master cylinder for my truck?
Old 06-07-2004, 11:04 AM   #16
76HighSierra
DAMN, I love Big Blocks!
76HighSierra's Avatar
Eric, I can almost guarantee that you haven't gotten all of the air out yet. I have run into this problem numerous times with GM vehicles. You likely have air trapped in the proportioning (sp?) valve. This normally happens when the master cylinder goes dry. It may seem that you got it all out (no more air coming out of the wheel cylinder), but it's likely just trapped up front. Bleed them at the valve. I know it's a b|tch to get at, but it's gotta be done. Then bleed them again at the back. Once or twice, I've had to resort to lifting the rear of the vehicle high up in the air, and letting it sit a while so the air would bleed upwards. I feel for you, it can be a pain.
Marc Bona
Hobbs, New Mexico
1976 1/2 ton GMC High Sierra.
454 c.i.d./ TH400. *Soon to get a mild warming over.*
3.40 rear.
76HighSierra is offline   Reply With Quote
Old 06-07-2004, 01:52 PM   #17
ocbaud
the master cylinder wasnt dry. the front of it(rear brakes??) was very very low, but there was still fluid in it.
also, everyonce in a while, there is a little bit of fluid covering the front of the brake booster, which tells me that i guess the master cylinder is going out?
Old 06-07-2004, 04:04 PM   #18
ocbaud
http://www.73-87.com/7387garage/chas...on/booster.htm
i did both those tests and everything seems to be working good. so i guess i'll take a few hours and bleed the whole system.
