Old 06-06-2004, 07:05 PM   #1
Madbomber88
Active Member
Madbomber88's Avatar
Valve Cover Problem
I uncovered an ineresting problem this weekend that stalled my restoration on my 71 K5. I have the complete front clip off and got to the point where I started to put all the new stuff on the engine and get her up and going. Took the valve covers off and noticed the previous owner had two full gaskets under each valve cover. Didn't think much of it, clean them all down, painted the covers, installed new RTV sealant and gaskets and proceeded to put them on. Then I notice the valve cover bolts bottom out and are too long. That must have been why he had two gaskets, to make the bolts work. Any one run into this? Where can I get stock (shorter) valve cover bolts? LMC doesn't appear to have them.
-Tim
71 Blazer CST
72 K20
Capt USAF
Madbomber88 is offline   Reply With Quote
Old 06-06-2004, 11:35 PM   #2
jhow66
jhow66's Avatar
Hardware store,Lowe's, Home Depot, autoparts store etc. By any chance would the motor be a 307? Reason I ask is that I ran into a problem on a neighbor's 307. He kept wearing a hole in each cover from the rocker arms rubbing. Come to find out that you could install them upside down. (one side had an angle to it). PO may have used 2 gaskets to cure this problem not knowing that they were upside down.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 06-13-2004, 06:59 PM   #3
TonyJohnson
TonyJohnson's Avatar
You could alway put washers on the top of the bolts until you get them shortened.
Tony Johnson
-- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer --
TonyJohnson is offline   Reply With Quote
Old 06-17-2004, 02:58 PM   #4
chaptr2
chaptr2's Avatar
Go buy some bolts at a harware store a little shorter than the ones you have. The guy probably put the longer bolts on beacause he put two gaskets on to stop his leaks. I have never heard of anyone doing that to valve covers, but the bolts shouldn't be that long. If you feel real tricky, go get some "all thread" from a hardware store (I think 1/4" rod) and put them in as valve cover studs. Once you get them in the head you will only have to put on washers and a nut and it works well. Plus you get the correct length you need.
This is only my opinion and it is subject to change.
70 GMC Short box stepside Blown 388 Stroker
72 K/5 Blazer 350/SM465/205
chaptr2 is offline   Reply With Quote
Old 06-17-2004, 05:23 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
You could also use the chrome t-handle style,that's what I use..
