Old 06-06-2004, 08:51 PM   #1
402Bowtie
402Bowtie's Avatar
Has anyone taken off the very rear crossmember from the bed?
I attached a picture of what I am talking about. I want to repair some rust at the back of the floor where the last crossmember is. It looks like the crossmember is welded to the floor. Has anyone taken the last crossmember off from the floor or have any tips on how to get it off, or can it be done at all? Thanks....John
402Bowtie is offline   Reply With Quote
Old 06-06-2004, 09:16 PM   #2
67cst
i love summertime
67cst's Avatar
yeah they are welded, any of the ones ive taken apart are anyways, i just used a cut off wheel on a grinder, be careful not to grind too much though, it doesnt take much to put a big groove in there
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 06-06-2004, 09:18 PM   #3
68C15
blood type; Retumbo
68C15's Avatar
Wink
tell you what, bring the whole thing up to me just the way it is. with trailer & fenders & I will find a use for them so you have no worries at all.
realistically though, get a spot weld cutter from body shop supply store & remove floor panels from x-member. do light rosette welds to reinstall when done. then carefully smooth welds off & no one will know the difference. take your time & pretend you are a plastic surgeon building a beauty pageant contestant.
Todd
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 06-07-2004, 04:59 AM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
The wood beds come apart easier. I only had 2 3" welds on each side between bedside and rear cross member. Like was said take your time cut shallow!
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
