06-06-2004, 09:14 PM | #1 |
4spd/auto tilt columns:What`s different??
If I had a collar from a 4spd tilt,will it be all I need to convert an auto column?Also,remove linkage.
72CheyenneSuperK20CustomCamper350/TH350,A/C 72SierreGrandeK2500350/TH350,A/C 72CustomDeluxeK20CustomCamperSB400/4SPD.A/C 72CustomC10SWB,TH400,project |
06-07-2004, 06:35 AM | #2 |
If you change the shift bowl, cut off the linkage arm, and make a cover for the lower end the appearance will be real close. I would also suggest screwing the cover on with the right length screws so that you lock the shift tube in place.
Jim |
06-09-2004, 11:40 PM | #3 |
Sounds like a good idea.
