Old 06-06-2004, 11:24 PM   #1
JOE BOB
Coil Resistor Wire
My coil reads: "12V External Resistance Wire Required". My coil is feed from a yellow wire out of the harness. How do I know if this is a "Resistance" wire. I keep reading about a "white braided" wire. Thanks, Joe Bob.
JOE BOB is offline   Reply With Quote
Old 06-06-2004, 11:43 PM   #2
MACKL
Almost done!
MACKL's Avatar
Joe Bob,
The best way to be sure is to use a volt meter to measure the voltage. If you measure around 12.6 volts, your wire is not a resister wire, if it measures around 9 volts, it is the correct wire with correct voltage. If you run the full 12 volts, it will burn up the points. (real fast)
If you do not have a volt meter, you can pick one up at most discount stores for less than $15.00. Good luck!
Kelly
The 1970 SWB Project
Removed 6cyl manual trans, manual everything
V8-350
Auto/PS/PDB
Blazer Fuel Tank
Behind the Marker Light Fuel Fill
MACKL is offline   Reply With Quote
Old 06-06-2004, 11:44 PM   #3
jhow66
jhow66's Avatar
It is--it is spliced into the resistance wire in the harness as the yellow wire also goes to the starter "R" post so that you get a full 12 volts when cranking for easier starting --when starter is released the current flows from ing. switch through the resistance wire to yellow wire to coil.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 06-07-2004, 12:15 AM   #4
JOE BOB
Great info! Thanks guys!
