Old 06-06-2004, 11:45 PM   #1
PHOENIX
Timing Chains, Cam Locks, Cam Buttons ?
Heres a bunch more questions I need answers for
Timing Chain:
If I have to buy a timing chain do I want a roller type?
If so I will check gm dealer for original type or get one of these, what do you guys think about original and these?
Edelbrock Performer-Link
Cloyes Gear True Roller
Crane Cams Roller
Cam Lock Plates:
All these do is prevent the cam bolts from coming loose?
Are these a good cheap investment ($5) or should I not worry about these at all?
Camshaft Buttons:
I understand these are supposed to hold the camshaft into place and not allow it to move. So these install between the cam gear and timing cover?
The crane cam roller timing chain set above comes with a "thrust bearing", is this the same as a button?
This part confusing me a little because there are different types and sizes.
How do I know what I need, from what I am looking at it seems as if they change depending on the cam gear, and timing cover.
As always any comments and help is appreciated here.
Thanks, Eddie
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 06-06-2004, 11:48 PM   #2
swervin ervin
You get what you pay for
swervin ervin's Avatar
I have the Edelbrock chain set. It's been good to me.
I also use a cam gear bolt lock. Cheap insurance if you ask me.
You don't need a cam button. They are made for roller cams.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 06-07-2004, 10:21 AM   #3
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Mike covered the basics for you, so I won't repeat.
I use Cloyes timing chains exclusively on all my motors.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 06-07-2004, 11:50 AM   #4
PHOENIX
Thanks guys, I appreciate the responses.
Ill go with the Edelbrock if need be because its cheaper ($45), but if for some reason its not in stock or something Ill go with the slightly more expensive Cloyes ($67).
Chris: Is there a particular reason you exclusively use the Cloyes?
Old 06-07-2004, 12:51 PM   #5
Captkaos
Captkaos's Avatar
Because they have a great reputation for quality and I haven't had a problem with them stretching. BTW, I think Cloyes makes Edelbrocks Timing chains.... yep, they do: http://www.edelbrock.com/automotive/timingchains.html
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 06-07-2004, 01:59 PM   #6
PHOENIX
Ill take that as good news.
How come the edelbrock above is $22 cheaper then the cloyes above?
The cloyes is a double chain?
I dont know jack about timing chains so stick with me
Is the Cloyes worth the extra $22 in this case (copared to that edelbrock)?
Mike is running a much stronger engine then I am and he has not had problems with his Edelbrock ( made by cloyes ) so I am sure the $45 edelbrock will be just fine. I am just curious about this stuff and want to learn.
Also what causes the timing chains to stretch?
Will the more expensive ones last much longer, if so about how many miles more could you expect?
Thanks for all the help Chris.
Old 06-07-2004, 02:41 PM   #7
Captkaos
Captkaos's Avatar
I think the difference is you are comparing a Edelbrok replacment to a Cloyes perf. You can get replacement Cloyes True roller for $20, and get 3 keyway settings:
http://store.summitracing.com/partde...LO%2DC%2D3023X
Is it worth the extra $22, only if you want the higher grade timing chain. No sure what one Mike is running, so... I use the one you listed though.
stretch - Usually it is how it is made and how the links are pinned/bushed together that causes them to stretch. In reality, the don't actually stretch, they elongate the bushing/pins that hold the links and therefore lengthen the chain. Cloyes has been making chains for 70+ years, so they definitely have the experience. I think you would be fine getting the cheaper version, just make sure you get a true roller, and I would avoid factory replacement (Just my opinion)
Edit: wrong link
Chris Lucas
1973 Chevy C-10
Captkaos Customs
