Old 06-07-2004, 10:49 AM   #1
kevin from oc
kevin from oc's Avatar
Will i have heat with the ac parts missing???
I have an ac truck my question is will the heater and blower function normally if i have all the ac stuff unhooked (compressor,condensor,evaporator all missing).Thank you...Kevin
kevin from oc is offline   Reply With Quote
Old 06-07-2004, 11:17 AM   #2
JimKshortstep4x4
Smile
The AC and heating are separate. They share the blower, so if that is working heat should not be a problem. There is a water shutoff valve in the heater hose that shuts off when the AC is on but I would assume that that is disconnected, also.
Jim
