06-07-2004, 05:04 PM | #1 |
love my truck
Timing for a 350???
What should be set at?cam is edelbrock 2102 in case you need this imformation.
06-07-2004, 09:09 PM | #2 |
start at 10º BTDC with the vacuum advance disconnected and plugged
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
06-07-2004, 09:19 PM | #3 |
With the good quality fuel lately I have been finding the need to turn the timing down on a couple of my trucks to keep them from pinging. My big bock is at 2btc at the moment. and my small block 400 is at 6btc
06-07-2004, 10:00 PM | #4 |
Fabricate till you "puke"
if you are running an HEI dist, i agree that 10 btdc would be a good starting point.....i am running "chit" fuel also, & set 6-8 up on my 383. The sb has an old points dist, with a Pertronics conversion & coil. there is much more mech advance in the old dist vs the HEI (20 degrees on the HEI, but i have 26 on the old dist!) I would need to time 12-14 up on an HEI, to have the total that i have on the point dist @ 6-8 up.....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
06-07-2004, 10:04 PM | #5 |
What direction do I turn the distributor to Advance timing. i.e. clockwise or counter. Second question is on the harmonic balancer timing plate, does before marks mean advanced, or the after marks?
72 C10 Cheyenne Super Full trim Factory tach dash A/C dash Factory tilt 350 / 350 power train - with Edelbrock components. |
