06-07-2004, 05:24 PM | #1 |
Truck addict
how to check a fuel pump?
What is the best way to see if my fuel pump is still working properly?
1956 Chevy Napco 1972 Cheyenne Super 1970 K20 |
06-07-2004, 05:46 PM | #2 |
unsrew the inlet to the carb put a hose on it into a jar turn the motor over for 5seconds and see if you've got gas in the jar
06-07-2004, 06:07 PM | #3 | |
06-07-2004, 06:08 PM | #4 |
Buy a clear inline filter with replaceable inserts and see the fuel pumping.
06-07-2004, 06:27 PM | #5 | |
06-07-2004, 08:52 PM | #6 |
Probably the best way is to use a line pressure gauge on the discharge side of the pump while the engine is running. NAPA sells a decent gauge that is a pressure/Vacuum gauge that works well.
Larry 72 Chevy SWB 4x4 71 Chevy SWB 4x4 My Work Truck "Don't confuse enthusiasm with capability" |
06-07-2004, 09:44 PM | #7 |
Watch out for your cornhole !
A new fuel pump is about 15 bucks. How much trouble is it worth to you to just put a new one on?
06-07-2004, 10:07 PM | #8 |
Truck addict
Tx Firefighter, thats a good point, but I would rather check it so if it is ok I can spend the $15 else where as the truck does need alot.
How much pressure is the fuel pump is suppose to put out?
06-07-2004, 10:53 PM | #9 |
stock pump not much maybe 4 5 psi max?
