Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 06-07-2004, 06:41 PM   #1
ItsMyRoadBiatch
Interchangeable Parts?
where can i find in writing which parts are interchangeable with an 84 c10 model truck? i know there has got to be some kind of manual or website or something out there that has this information... any help would be appreciated!
ItsMyRoadBiatch is offline   Reply With Quote
Old 06-07-2004, 08:38 PM   #2
Blue Beard
Blue Beard's Avatar
Could try Hollander parts interchange manual....
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 06-07-2004, 08:55 PM   #3
ItsMyRoadBiatch
i tried it, and they have everything except the years that i am looking for
Old 06-16-2004, 10:31 PM   #4
dswancutt
Get a GM parts manual off of eBay. I have the 73-78, 79-84, and the 85. It's the best way to cross reference parts. Make sure you get the parts catalog, NOT the illustration catalog, as it only has the group codes, not the actual part numbers. The illustration catalog is helpful, but not necessary.
Hope this helps
Doug
dswancutt is offline   Reply With Quote
Old 06-18-2004, 02:36 AM   #5
GMC1tondually4dr
A crash book by Mitchell also works. Body shops have them. Mostly for sheetmetal, interior and suspension, some engine stuff. I have one from 1995 and it works for 81 to 91 subs and one tons,and all the newer stuff. Look up your part, then check to see if it is used in other years. Thats the way I found out for sure that all front doors on 73 to 91 subs, 73 to 87 trucks and one tons are the same. Same part number for the door shell.
GMC1tondually4dr is offline   Reply With Quote
Old 06-18-2004, 11:28 AM   #6
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
This isn't actually accurate. The outer skin is the same, but the inside is not. Doors are split 73-76 and 77-91 for the fronts. 77-91 has the provision for the power windows, where the 73-76 does not. A complete door will bolt up to any year, BUT if you shell is bad, you cannot put 77-91 guts in a 73-76 and expect it to work, same is true in reverse.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 06-18-2004, 09:52 PM   #7
GMC1tondually4dr
I stand corrected, the insides are different ,but the part number is the same for the door shell its self. In a body shop if the insides have to be transfered it is done by the bodyman and pays accordingly. This is pointed out in the crash book.
I suppose I am assuming that a guy that is swapping doors can swap the insides too.(naaaah.......#1, I am assuming.....#2 my wife says I am wrong ALL the time). So I AM WRONG..............she said that I WILL be punished.... ......hmmmmm........maybe ....not .....that....bad ....after all...
Old 06-18-2004, 10:05 PM   #8
GMC1tondually4dr
Kaptkaos, I was wrong. I should have said '77 to '88 regular trucks and '77 to 91 'Burbs and 1 tons. I am sorry for any confusion (Senior moment I guess )
