Old 06-07-2004, 10:19 PM   #1
Jeremy_5
Truck addict
Jeremy_5's Avatar
leaking gasket on carb?
Recently I have noticed gasoline stains on my carb, I was wondering if this could be from a leaky gasket or improperly torqued bolts?
1956 Chevy Napco
1972 Cheyenne Super
1970 K20
Jeremy_5 is offline   Reply With Quote
Old 06-08-2004, 12:09 AM   #2
jhow66
jhow66's Avatar
What kind of carb?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 06-09-2004, 01:08 AM   #3
Jeremy_5
Truck addict
Jeremy_5's Avatar
4 barell quadrajet
1956 Chevy Napco
1972 Cheyenne Super
1970 K20
Old 06-09-2004, 01:16 AM   #4
jhow66
jhow66's Avatar
Try tighting all the bowl screws. Just stains or is there gas on manifold?
Old 06-09-2004, 03:07 PM   #5
Jeremy_5
Truck addict
Jeremy_5's Avatar
it just looks like stains on the carb, no gas on the manifold, but it is leaking somewhere.
1956 Chevy Napco
1972 Cheyenne Super
1970 K20
Old 06-09-2004, 03:42 PM   #6
jhow66
jhow66's Avatar
Normal condition --after a period of time gas will wick thru gaskets,pump rod hole, mist from pump squritor etc. Take a little carb cleaner and spray it every so often if you want it to stay clean.
Old 06-09-2004, 05:05 PM   #7
Jeremy_5
Truck addict
Jeremy_5's Avatar
thanks for your help, do I just spray the carb cleaner down the throat?
1956 Chevy Napco
1972 Cheyenne Super
1970 K20
Old 06-09-2004, 08:41 PM   #8
jhow66
jhow66's Avatar
No-just spray the outside to keep it clean.(will not hurt the inside to spray it though)
Old 06-10-2004, 01:49 AM   #9
71-longbed
Its Magically Delicious
71-longbed's Avatar
i've always wondered about that ... if you spray'd carb cleaner down the primary barrel ... are you simply washing gunk down and around you float needle ... i've heard of guys removing the idle mixture screws and spraying it around through there .... i guess my question is .. Can you do more harm then good with carb cleaner ????
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 06-10-2004, 09:09 AM   #10
67chevemall
67chevemall's Avatar
I'd say it depends on the time and method it is applied.
To spray a whole can down the throat of a cold, not running engine would be a bad idea! To spay a little down a hot running engine would be opposite.
Ect....
Personally I just clean the outside of the carb. If you need to spray it out inside to make it run better it is probally something else. I would rebuild the carb.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
