06-08-2004, 08:04 AM | #1 |
5 speed upgrade
Hi
is there a late model 5-speed tranny that will bolt up to a 235? if so what rear ends are the best with this application? i tried search but came up with nothing! thanks |
06-08-2004, 11:27 AM | #2 |
lot of good info on the stovebolt web site that addresses these swaps.
06-10-2004, 10:23 PM | #3 |
I'm going to be doing this swap in the next two weeks or so. I'l be doing to my 55 chevy with a t-5 speed trans. It looks like it will work...Joe
Joe |
06-12-2004, 09:31 AM | #4 |
Joe
you gonna be using a 235? which model 5-speed did you select? flywheel,clutch set up etc? where ya located in AZ? we are in the verde valley! thanks |
06-19-2004, 06:16 PM | #5 |
www.inliners.org has a lot of good info. The T5 from an S10 is very popular. I even put one behind my 350. Use the stock clutch linkage and a clutch plate from an 85-89 Astro van.
Silence is golden, duct tape is silver. - Scott |
06-23-2004, 11:37 PM | #6 |
I just found this site and I am exstatic. I have a 49 in the works and was wondering about the same situation. I have already purchased a 4.3 and a 5 spd. The gear ratios in the tranny should make it quite fun, but what about the slave cylinder? Can an aftermarket scatter shied be machined down to accept different bearings to eliminate it?
06-27-2004, 10:39 AM | #7 |
we are planning on doing the same thing to my 58 GMC. We have a nice 283 to drop inot it and then we will hook up a 5 speed to it. Don't the 5 speeds all have hydraulic clutches??
06-28-2004, 09:07 PM | #8 |
as far as the T5 in the S-10's (newer), yes. i'm not so sure bout the 80 models, but it probably does...
79 Chevy Silverado 454, TH350 4.11:1 posi. 03 Subaru WRX Wagon, EJ20 5MT AWD. 53 Chevy 3100. 216, 3MT, 4.11:1 |
07-25-2004, 05:49 PM | #9 |
Has anybody used a Tremec TKO in a 49-54 ??
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
08-22-2004, 01:07 PM | #10 |
Here is a link to my buddies web site. he has put together some good info here. I have done this swap to my 52Suburban and we did his 53 Chevy pick up together. http://www.mongosgarage.com/tech/mongo/t5/index.htm
