Old 06-08-2004, 12:13 PM   #1
atcavage
Oil pump pressure
Could someone please tell me what psi a normal oil pump for a 350 smallblock should be pushing versus a high volume one?
1972 1/2 ton Chevy C10 V-8 350, crate engine, with Flomaster dual exhaust. She's Old Blue the Truckinator (no relation to Arnold )
atcavage is offline   Reply With Quote
Old 06-08-2004, 01:25 PM   #2
Jeepster376
Jeepster376's Avatar
Depending on the rpms, stock oil pressure should run between 20-60 PSI. High volume pumps may run up around 80 psi.
72 Cheyenne Super 4x4 SWB
Jeepster376 is offline   Reply With Quote
Old 06-08-2004, 01:31 PM   #3
LONGHAIR
That's a really hard question to answer, too many variables. The high volume pump has longer rotors and pushes more oil per revolution. The pressure from the pump is internally regulated by a valve/spring. At idle, the high volume pump may have more pressure than the stocker but once you get high enough for the regulator to start cutting it down, it won't matter at all. A high volume pump may be able to keep the pressure up in an older motor with looser bearings but it would be better to fix that first.
LONGHAIR is offline   Reply With Quote
Old 06-08-2004, 08:03 PM   #4
crazy longhorn
Fabricate till you "puke"
I have a 10555 Melling on my 383(hy vol/hy pressure) It runs 80 psi @ idle cold, & settles to 40 psi @ idle hot, runs tween 65-70 psi hot @ 3000 rpms. A stock pump will generally run around 20 psi @ idle (hot), & 50 -55 @ 3000 revs (that is assuming fresh bearings). crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
