blinkers quit working......need help
The other day both of my blinkers quit working on my 76 c10. Both turn signals quit, they dont make the clicking noise nor do they blink at the instrument cluster. The hazard switch which works in conjunction with my blinker switch still works fine. I checked fuses and took the steering wheel off and examined the blinker switch but everything looks fine so im not sure. Anyone have any ideas what could be the problem.
Thanks in advance, Clynt |
I'm back with 2nd truck!
On your fuse block check the round metal fuse on the bottom left. This is for the blinkers. You may have another one up top but the bottom one can pop out from time to time by accidently knocking it out of socket. If that doesn't work try replacing it.
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
Ob-Gyn Kenobi
brake lights still work?
'85 GMC Shortbox... I used to have a firm handle on life....then it broke off. |
Yes my brakes still work fine and when i turn on my hazards everything still works also???? Im lost!!
hey man mine messes up too. when i have my head lights on none of my blinkers turn singles work, when i have my lights off, only my left turn single works today i tried my left turn single and both sides was flashing. wires suck
When both sides quit at once, and the hazards work, it's a sure bet the flasher can is bad. Try swaping the two cans and see if the hazards stop working.
What and where is the flasher can?
See 79BIG10 's post above, he describes it.
Thanks, that fixed the problem.
