06-09-2004, 07:02 PM | #1 |
Difference between 8cyl and 6cyl factory tach??
The factory tach I just bought has 8cyl stamped on the back of the housing. Will it read correctly on a 292 6cyl??
I know what your thinking.......I have ESPN. Sometimes it's easier to do things the hard way. Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! |
06-09-2004, 07:32 PM | #2 |
no it will not
06-09-2004, 09:31 PM | #3 |
Aftermarket tachs have a slide switch on the back: 6 Cyl or 8 Cyl; or 4-6-8, depending.
06-09-2004, 10:44 PM | #4 |
Led Sled! Discs R 4 ME!
The 6 cyl tach will count 6 fires of the coil and think the rotor has completed one revolution then there is 2 to go.
you will need a 6 cyl tach if you want to keep it factory |
06-11-2004, 09:47 PM | #5 |
See if you can dial it in to the correct rpm using the set up screw inside the tach head ... pictures shows a hole.. yours may still have a sticker covering it. Just get another tach meter that reads correctly to dial it in.
I just put tach cluster on the rad cradle.. hook a set of tach wires to it and ground the cluster to the chassis. Run the truck, set the rpm, then install correctly.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
06-14-2004, 01:07 PM | #6 | |
06-14-2004, 07:50 PM | #7 |
Deuce,
I had PM'd you the instructions back on 6-10-04 in regards to the tach. It looks like you have not read the PM yet. Jim |
