Old 06-09-2004, 07:49 PM   #1
3rdGenrationChevyman
What me ugly?
3rdGenrationChevyman's Avatar
Big meats on stock rims...
I was wondering... whats the biggest tires I could place on my stock rims, stock height. I have a 2wd `70 C-10 Long bed w/air shocks in rear... my current tires a in dire need of replacement & I would like to toughen the look up a bit. thanks!
3rdGenrationChevyman is offline   Reply With Quote
Old 06-09-2004, 08:50 PM   #2
1972ChevyGuy
1972ChevyGuy's Avatar
I seen a post yesterday where a guy fit ~345/15s. I just bought some 295/50s and they struggled to mount them on my 8" rim, but it can be done. They fit prefectly fine.
1972ChevyGuy is offline   Reply With Quote
Old 06-09-2004, 09:40 PM   #3
crazy longhorn
Fabricate till you "puke"
I have found that a 255/70/15 fits an 8" wheel & leaves a perfect 8" wide footprint when the clutch comes up as a rule, if you look at the tread width, it should be really close to the width of the rim(to get full use of the rubber you are running).....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 06-09-2004, 09:42 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
My 295/15s are giving me a full tire patch ln a spin. They are a good fit for an 8" rim.
piecesparts is offline   Reply With Quote
Old 06-09-2004, 10:30 PM   #5
sixty8chev
The Sauz
sixty8chev's Avatar
My 31x10.5's leave a pretty decent patch when aired down but i dunno if thats look your goin for.
68 lwb 2wd (spread between 3 garages)
72 Burb - Flat Deck
92 Yukon 3" lift - 33's - the new bush pig
01 Sierra - Daily Driver (for now)
sixty8chev is offline   Reply With Quote
Old 06-13-2004, 04:00 PM   #6
What me ugly?
OK, I put 31x10.5`s`s in the front, 33x10.5`s in the back, BFgoodrich All-terrain T/A`s, rides mighty nice, looks pretty mean, too...
