06-09-2004, 09:28 PM | #1 |
Anyone used the body patch panels?
I received my cab corners today, as well as front fender bottoms, to repair rusted areas.
I am having a body shop install them, but I was test fitting them today. They fit O.K., but don't exactly seem to line up as good as I was hoping. They will have to be tweeked a bit. Has anyone else used some of the patch panels, and were you able to get them to fit good enough? I am not sure what brand they are.
72 C10 Cheyenne Super Full trim Factory tach dash A/C dash Factory tilt 350 / 350 power train - with Edelbrock components. |
06-10-2004, 10:18 AM | #2 |
1969 Custom 30 wrecker
I had good luck with all the panels I ever used.
I've done 3 cab corners, 4 rocker panels, 1 driver floor board, 1 floor support, 1 outer floor panel and some bolt on parts such as tailgates and front bed panels. No complaints here.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
06-10-2004, 10:35 AM | #3 |
You always have to tweek these types of parts to get them right but I have never had any problem with them.
One thing though, I don't think I would mess with fender bottoms. It is far easier to just replace the fender. By the time you by the part and pay someone to install it, you could have had a new fender. Fenders are cheap, body time is not. You sould only use patch panels on non-removable bodyparts |
06-10-2004, 10:43 AM | #4 |
I installed both cab corners, inner and outer rocker and the fender patch under the battery and they all seemed to fit well. I'm not sure on the brand name but they came from Scotts Super Trucks.
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
06-10-2004, 09:26 PM | #5 |
The trick is to only use as much of the patch panel that is needed to fix the rust.
06-10-2004, 11:37 PM | #6 |
Thanks guys. Dubie, the panels I have came from Scotts as well. They are definately bigger than I need Randy, so I will only use as much as needed. Especially the cab corner pieces.
