Old 06-10-2004, 12:50 PM   #1
UP GRADE
one set closer
UP GRADE's Avatar
Gas Tank
is there any different between the blazer gas tank and the suburban gas tank (67-72) i have the chance to buy ethier one of these tank. do both holds the same gallons of gas are both are both the same height and witdh are the sending units the same.and if not the same which one will be the best to install. :p :p
UP GRADE is offline   Reply With Quote
Old 06-10-2004, 01:39 PM   #2
71swb4x4
71swb4x4's Avatar
I do know that the filler is in a different location. I can't tell you where for sure, but if I remember right the blazer is on the side near the corner and the sub is on the side in the middle.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 06-10-2004, 03:06 PM   #3
UP GRADE
one set closer
UP GRADE's Avatar
anyone esle.
