![]() ![]() will this cam work, if not what else shold i do ......any sugestions?
TIM ![]() '71 CUSTOM C-10 torch red ,350 roller GM crate,3.73 GEARS, REAR 4"DROP SPRING, FRONT 2.5" DROP SPINDLE-1.5"lower spring, FRONT=17x8(4.5bs) W/265-60-17, BACK=17x9.5 (5bs)W/285-60-17, Vintage Air Sure Fit AC------NEVER ENDING PROJECT!! |
That cam should work no problem.
Tim |
Thanks For The Reply.................anyone Else Have Any Input Or Thought On This Matter.
What valve springs are you planning to use?
72 SWB parts and pieces Oklahoma |
I Was Going To Run The Stock Spring, Will It Work?
If Not What Spring Has The Same Dim's As The Vortec Stock Spring But Is Tall Enough And Stiff Enough For That Lift ".510"? All Help Welcomed.
No the stock spring won't work with the zz4 cam. The stock vortech springs are only good for a mild cam with .470 lift max and thats pushing it a bit IMO. I think you can use the factory LT-4 springs and retainers on the vortech heads and have enough clearance for the zz4 cam. Maybe someone else knows for sure.
72 SWB parts and pieces Oklahoma Last edited by Stroker; 06-14-2004 at 05:57 PM. |
ran out of money
i might be wrong but an LT4 engine might have the right valve springs that your looking for... i have vortec heads and i have a .510 lift cam but i forget what springs i used.... i know they were comp cams springs though...... truck has some life now!!
Rat
Modify everything, leave nothing alone!~ ![]() ![]() |
ZZ4 & LT4 use the same 1.32" OD valve spring. If you use them, don't buy them singly for $4 each. GM sells a set of 16 for ~$35 under pn 12495494. Comp makes a cutter for enlarging the spring seats if necessary.
![]() did you have the guides cut or did you just swap the springs in your garage(or driveway). ![]() ![]()
