Old 06-11-2004, 10:07 AM   #1
UP GRADE
one set closer
UP GRADE's Avatar
Angry sway bar
did anyone save the pictures of TX FIREFIGHTER sway bar installation the pictures was deleted when the board was updated
UP GRADE is offline   Reply With Quote
Old 06-11-2004, 11:59 AM   #2
smokekiki
Mike
smokekiki's Avatar
not Tx firefighters But it might help....http://www.low69cst.freeservers.com/CamaroBar.htm
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 06-11-2004, 03:53 PM   #3
neonlarry
neonlarry's Avatar
I think he is looking for front bar install. This post of his has a couple of pics, I don't know if there was another with more. http://67-72chevytrucks.com/vboard/s...d.php3?t=72338
I was just on the F\S board and someone had these also.
http://67-72chevytrucks.com/vboard/s....php3?t=107349
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 06-12-2004, 01:21 AM   #4
EdB
I have the set as well as the write up. I had to visit several junk yards but
found one and did the install. One of the part numbers was wrong for the
middle brackets. Do you want all of it or the pictures? Can I post several
pictures on one post?
EdB
EdB is offline   Reply With Quote
Old 06-12-2004, 06:15 AM   #5
krue
Designated A-hole!
krue's Avatar
Ed you can post up to 5 pics in one post. How about posting it on the FAQ page. I am interested in doing it myself.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 06-12-2004, 07:24 AM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
middle brackets. EdB
One of my part numbers was wrong? I copied them directly off of the GM reciepts when I did the article.
Old 06-12-2004, 01:16 PM   #7
EdB
I will post it on the FAQ page. TX, I got the large sway bar. it had the brackets
with it. One was bent so I went by your instructions and ordered a replacement.
I needed the large bracket but got the small one. Doubled checked with the
Chevy dealer and it was the correct number for that bracket. I think that you
might have gotten them transposed. I straightened the bent one and it went in
fine. No problem, Thanks for your info. EdB
