spark plugs??
what is the best plug to use in my 350, and what gap should they be set at?
btw: it is just a regular 350 with headers.
1972 k10 4x4 LWB (Sold in 2005 ![]() |
I am glad you asked this again. I was searching for this earlier and didnt find the info from the past. I will assume this has an HEI.
I will watch this too. Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
points distrib or hei???
it is points
r44ts at 0.35
Champion RJ12YC .035 points, .045+ HEI.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
hmm maybe thats why my new egine runs a bit rough?? I gapped my plugs to .035 but i have an HEI. Should it be .045 for all hei's in 350's??
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
Howzit?!?
I think so Doob
Jason Hawaiian-J 70 Longbed, 307, Edelbrock Carb 1404, Edelbrock Intake 2101, Dual Roller Timing chain and gears, 214/214 cam, Comp Roller Rockers, dual Flowmasters. 1999 Chevy Tahoe 2004 Mini Cooper S 71 BMW 2002 - Sold |
At least .045, if you want to experiment or have a hotter coil I would try .050 or more.
#10 | |
Led Sled! Discs R 4 ME!
![]() Join Date: Jan 2001
Sorry I cant give you a plug number but a plug set up to run a larger gap is better because the electrode will be perpendicular to the plug. A plug set up for a smaller gap will have an odd angle when gapped to .050-.060 and causes an uneven spark. Will it work - Yes Will it work to it best potential - no |
![]() Join Date: Sep 2001
I gap my plugs at .45 and I'm still running points. I get pretty good performance too.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
I run R45ts on HEI's there a hotter plug You can go up a few ranges like r43 is colder than r44s and r45s are hotter than r44s not sure if they have r46ts and r47ts never checked lol.
#13 |
Its Magically Delicious
what kind of plug would recommend with a stock 350, pertronix igniter under the cap... and a crane adjustable vacuum advance .... r45ts or something different ???
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
#14 |
Id just run plain Ac Delco R45TS gapped at 0.45
