Old 06-11-2004, 02:58 PM   #1
chipotledude05
Strategery
Arrow Dana 44's Wanted...
I'm looking for Dana 44's...both front and rear.
This way I can easily convert to disc brakes on my '61 4x4.
I need a front axle with open knuckles (of course), mainly for the conversion to discs.
The rear on my truck, however, has quite a bit of slop in the pinion and would be easier, and cheaper, to just replace outright.
So if anyone has a pair, or even just one of these axles in the Dallas area, please leave a PM or send an email.
Thanks,
Matt
chipotledude05 is offline   Reply With Quote
Old 06-11-2004, 05:04 PM   #2
1FaastC10
1FaastC10's Avatar
as far as i know, GM never used a 44 in the rear. you might want to look for a 10/12/14 bolt corprate axle. probably lots cheaper and definitely easier to get parts for.
1FaastC10 is offline   Reply With Quote
Old 06-11-2004, 06:38 PM   #3
chipotledude05
Strategery
thanks for the correction. A standard 12 bolt will do nicely for my application.
matt
Old 06-11-2004, 07:29 PM   #4
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Wink
Hey Mild Pepper, Where U At ?
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 06-11-2004, 10:22 PM   #5
Mike C
Mike C's Avatar
The 67 1/2 ton 4x4 had Dana 44's in the rear. At least some. I looked a t a67 GMV V6 short step SM420/Rockwell with 3.54 geared 44's in both ends about 15 years ago. It was a fire dept truck and all original. 25k miles.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-11-2004, 10:52 PM   #6
chipotledude05
Strategery
about 20 minutes east of Dallas, TX...right off of I-30
Old 06-15-2004, 10:53 PM   #7
1969 GMC
1969 GMC's Avatar
dana 44 rearends appeared in '67 and '68 in 2- and 4wd trucks. my guess is they came predominately in GMCs. However, a 67-8 4x4 will have the same closed knuckles and drum brakes that you have now. I would swap both axles from a '73 up K/5 or K/10, as they are very common and parts are easy to get.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 06-15-2004, 11:55 PM   #8
mkundo
I have a compleat Dana 44 with disk brakes and open knuckles. $150.00 and you pay the ride.
mkundo is offline   Reply With Quote
Old 06-19-2004, 01:52 AM   #9
chipotledude05
Strategery
6 lug right? and also, what gears are in that?
thanks,
matt
