Old 06-11-2004, 11:36 PM   #1
jostrans68
Jostrans68
jostrans68's Avatar
fuel sending Unit differences
6 cyl has smaller tube? how much will this effect a 350 mild build? thanks Jack
[CGTW Member
former 67-72 now with a 96 silverado
jostrans68 is offline   Reply With Quote
Old 06-11-2004, 11:46 PM   #2
jhow66
jhow66's Avatar
Should be fine (unless you are planing to turn the motor in the 7000 rpm range).
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 06-12-2004, 05:48 AM   #3
GMCPaul
1967-71 6cylinders did have a smaller diameter line which was 5/16", 1967-71 8-cylinders used 3/8" lines on sender & from tank to pump, as stated prior it should only effect very high RPM's and WOT acceleration.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 06-12-2004, 10:13 AM   #4
Sweet72
Sweet72's Avatar
Maybe the GMC's were different. My '72 with 307 V8 came with the 5/16 lines.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
