Old 06-12-2004, 10:03 AM   #1
dubie
dubie's Avatar
Fan shrouds
I need to find a fan shroud for my truck but I'm not sure what exactly will fit. My 350 is in the inline 6 spot but I have a long 9" water pump on it with a clutch fan and am running the stock 2 or 3 core rad. Anyone have any suggestions on what would be a good donor?? a van or maybe a big block??
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 06-12-2004, 10:14 AM   #2
cdowns
cdowns's Avatar
i don't see why you can't use the stock shroud all you'd have to do is locate the fan in the shroud with the use of the proper width fan spacer available at any good autoparts store
Old 06-12-2004, 10:14 AM   #3
crazy longhorn
Fabricate till you "puke"
a stock shroud for the 67-72 should work with the long waterpump (2wd/sb/ V8). im not sure on the clutch fan , as far as lenght, but my setup ran the stock sb shroud with a short spacer & flex fan......untill it was swapped to dual electrics crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 06-12-2004, 10:26 AM   #4
dubie
dubie's Avatar
I plan on swapping out the clutch fan for electric ones in the coming months, but for now I just need one that will work. I am off to the yard this morning and will be sure to pick one up. Thanks guys
Old 06-12-2004, 10:51 AM   #5
gr8scott51
gr8scott51's Avatar
Tim, I have the stock 2WD shroud. As you know, I have the exact same set up as you. It works fine although the fan is not within the shroud. I've been told the big block 4X4 shroud would enclose the fan - although that's just hearsay at this point. To make sure nobody loses a finger in my fan, I put an extension on the shroud - just a 3 inch wide strip of aluminum pop riveted to the shroud. Have fun at the wrecking yard.
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 06-12-2004, 11:59 AM   #6
junkyardjohn
junkyardjohn's Avatar
TIM -- A FAN SCHROUD OFF A 80s VAN WILL FIT WITH NO MODIFICATIONS. THE HOLE THAT THE FAN BLADE GOES INTO IS A LITTLE BIGGER (ALLOWING YOU TO USE A BIG BLOCK FAN) & THEY ARE ABOUT TWICE AS THICK AS A STOCK TRUCK SHROUD. SEE PIC.S.. VAN SHROUD IS ON THE RIGHT IN PIC.S & IS ACTUALLY A MUCH BETTER SHROUD, & IS REDILY AVAILABLE. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 06-12-2004, 03:38 PM   #7
68C15
blood type; Retumbo
68C15's Avatar
do you really need one just yet?
I am running a 350 with clutch fan & no shroud. so far the weather has been up to about 92 F & truck has not gone past 195 F. I do plan on putting in dual elecs though.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 06-12-2004, 09:56 PM   #8
junkyardjohn
EVERY TRUCK NEEDS A FAN SCHROUD. THIS ISN'T JUST MY OPINION..... IT'S A FACT. JOHN
junkyardjohn
DON'T RENT U-HAUL
Old 06-13-2004, 04:19 AM   #9
Edmond
Edmond's Avatar
When I bought my truck five years ago it didn't have a shroud,
and it still hasn't one today. Never had problems with cooling, not even when towing.
But it looks better with a shroud, so one from a 80's Van looks like a good option.
junkyardjohn, could you give me more specific info on which Van (Year) I could use? It's easier to find parts for a Van over here.
One day I do hope to upgrade to a dual electric fan setup.
Cya,
Edmond
1971 Chevy C/20 Longhorn, 350/TH400, Edelbrock Performer, IMPCO 425 LPG Carb
1974 Chevy Camaro Z28 (Original)
Capelle a/d IJssel,
The Netherlands
Edmond is offline   Reply With Quote
Old 06-13-2004, 11:34 AM   #10
junkyardjohn
EDMOND -- LOOK FOR A LATE 70s TO LATE 80s VAN. THEY ARE PRETTY COMMON. JOHN
junkyardjohn
DON'T RENT U-HAUL
Old 06-13-2004, 12:36 PM   #11
68 Stepside
huh?
68 Stepside's Avatar
Thanks for the tip John! I'll have to go van hunting, as my shroud isn't even close to correct (the previous owner put it on with zip ties ).
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
