Old 06-12-2004, 10:51 AM   #1
b454rat
Hopefully some useful info
I hope this info will be helpful to some folks, it was for me. I'm swapping axles in the 62 4wd burban that I have, and was looking for some axles that will bolt in. The front is easy, any 73 and up will bolt in. But the rear, only Gm 1 tons will bolt in, with the 40 1/2" spring pad width. Well, after some searching, measuring, and some head scratching, I found out that 79 and older Ford, HEAVY DUTY 3/4 or maybe 1 ton have the same spring pad width. These are Dana 60s rears, I don't know about the Dana 70s, the junkyard didn't have any. I measured regular 3/4 tons, and they have a wider pad width. So, if anybody is swapping axles on a 60-66 4x4, there is an axle besides the heavy ass 14 bolt that will bolt in. I will get some pics when I can. Hope this helps someone!!!!
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 06-12-2004, 01:56 PM   #2
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Excuse my ignorance, but how does this compare to the '67-'72 leaf spring rear suspension (2wd and 4wd if there is a difference)? Is there a more readily available swap for '67-'72s?
badpeanut is offline   Reply With Quote
Old 06-12-2004, 02:00 PM   #3
b454rat
I'm not sure on the 67-72s, I never had one, so I couldn't give you a good anwser. I know that the 2wds use coil instead of leaves, but I know that the 4wd use leaves on 1/2 tons. If I remember, I will measure a 67-72 and see what I can come up with.
Old 06-12-2004, 08:19 PM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
The 67-72 4x4(10&20) have the same rear spacing 40.5". The 2wd 67-72 rear leaf sprung axles are wider than 40.5".
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
