350 running like $hit
i just rebuilt the quadrajet 4bbl carb on my pickup, bolted it on, and dropped the battery in and cranked it up and it runs like crap. when i really open it up it runs great, it just won't idle smooth. before i rebuilt the carb, the engine ran smooth, it just didn't accellerate good. what's up with this???
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck Last edited by Robert1970C20rstbukt; 06-12-2004 at 12:25 PM. |
Possible vacume leak?
-1968 Chevy SWB = Frame Off/383/Muncie Car 4 speed -1968 Chevy SWB = numbers matching 307/Truck 4 speed. -1966 Chevy II = 2 door No Post/130,000 Orig miles/230 6cyl/powerglide/Vintage AC -1972 Chevy Nova = 2 door/412 Small Block -1927 Ford Roadster = Homebuilt/widened 8"/350/ Custom Everything. |
My son, my joy.
Sounds like you need to adjust the idle mixture.
Designated A-hole!
BTW Welcome to the board from South Mississippi. That's a heck of a screen name you got there!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Thanks guys, will check that out tomorrow morning. Yeah, I did pick a long name. My name's Robert, my truck is a 1970C/20, and it is a rust bucket. It needs new rockers and a left cab corner, and probably 5 gallons of bondo.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
huh?
![]() Join Date: May 2000
Sounds to me like a major vacuum leak. Be sure you didn't knock off the vacuum modulator line at the back of the intake, and make sure the carb is sealed well against the intake. I had the exact same problem with a 78 F100 that I was working on....the carb base gasket didn't seal well to the intake, so it wouldn't idle, but it'd run fine when I was on the gas. I replaced the base gasket, snugged down the carb, and it ran perfect after that.
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
OK, thanks. I'll check that too. I replaced every hose in the engine compartment so it's either a mixture problem or a leak like you said.
